Post by petehodges on Oct 30, 2016 13:50:56 GMT 1
hi lads got bike back now but a few jobs to do so any info / advice would be great so I've got an lc /ypvs with METCHAMETEX arm its got a rear ap lockhead calliper i,m running tazzrotti sets as well problem being that the ypvs rear cylinder doesn't work right for a start the arm from the sets doesn't go up straight into master cylinder ? its all wonky i,m no bike builder so could do with a bit of help with this please i think the one of an r1 would fit is it an improvement as this one just won't bleed up neither if i upgraded the cylinder to say brembo would this be better i try & get some pics up later cheers pete
Post by veg on Oct 30, 2016 14:03:38 GMT 1
Could do with some pics. I had loads of problems with tarrozi rear sets on my hybrid ended up junking them they are far from the best. If you post pics it might help for others to advise you, atb
Post by petehodges on Oct 30, 2016 14:46:41 GMT 1
Could do with some pics. I had loads of problems with tarrozi rear sets on my hybrid ended up junking them they are far from the best. If you post pics it might help for others to advise you, atb pics added mate
Post by petehodges on Oct 30, 2016 22:26:03 GMT 1
anyone ?
Post by rich on Oct 30, 2016 23:01:35 GMT 1
The reason it won't bleed is because the bleed nipples on the Lockheed are at the bottom so you're never gonna get the air out. You need to bleed it with the caliper off the bike with the caliper positioned with the nipples at the top. You'll also need something between to stop the pistons coming right out. An R1 master cylinder is basically the same as a YPVS so won't be any better. Having said that, the positioning of the master cylinder does look wrong, it appears too high and far back. You really need a new mounting bracket to bring it down and forwards so the actuating lever on the rearsets will be pushing more upwards.
Post by JonW on Oct 31, 2016 0:25:06 GMT 1
The pushrod into the master needs to be straight and not at an angle, so it slides in easily. you will fix that issue with a new bracket or adapting the one you have with some grinding and a new mounting hole.
The caliper bleeding is as has been said above, the nipple lets the air bubble out, air bubbles rise, hence you need the nipple at the top to bleed them.
