Post by looey on Oct 29, 2016 13:43:36 GMT 1
Can anyone confirm the exact dimensions of the correct fuses for a 4L0 350 ?. I have an LC here that looks like it has a new/replacement fusebox. Some of the fuses in there are 5mm x 20mm and are not a tight fit in the holders. Some are 6mm x 30mm and fit the clasps well but are too long Looks like 6mm x 20mm would be a good fit but don't look readily available ?? Cheers
Post by stusco on Oct 29, 2016 14:34:03 GMT 1
Norbo sells the correct one but that's no good waiting a week for one then it blows again
Post by looey on Oct 29, 2016 14:45:15 GMT 1
I'm not 100% sure the fuse box fitted on the bike takes the standard size fuses for a 4L0, hence why I'm trying to find out what size the correct fuses measure (length & cap diameter).
If I just bought fuses from Norbo they might not fit.
It's not blowing fuses, I'm just not happy with the fitment of the fuses at the moment, so need to replace them.
If anyone could give me accurate dimensions (with verniers or similar), that would be very helpful
Post by looey on Oct 30, 2016 10:45:27 GMT 1
F.Y.I
25mm x 6.2mm
Post by 4L0luvvr on Nov 1, 2016 22:07:20 GMT 1
Hi
I have had the same problem with glass fuses on my 4L0. The genuine Yamaha fuses are slightly shorter than some that are generally available which fit snugly into the fuse box without pushing the terminals to out too far to enable the wires to click into place.
The 10a fuse is part number 1A0-82151-00 x3 required the 20a fuse is 1A0-82161-00. These are expensive at £3-4 per fuse but they fit properly. Good luck with it!
Post by looey on Nov 2, 2016 8:43:54 GMT 1
Yeah thanks.
I've since found out that the fuse box fitted to this particular bike is a pattern item and although it takes the standard 25mm fuses, it is much more fussy about the fitment because of the way the box is made. Anything other than the correct 25mm fuses are a pain to fit.
I've since found the correct fuses. Think I paid £4.50 incl. delivery for 6 fuses (4x 10A & 2x 20A).
