Post by petehodges on Oct 23, 2016 22:33:06 GMT 1
hi as above are they all the same lenght? could do with them a little longer any links cheers
Post by markhoopy on Oct 23, 2016 22:37:58 GMT 1
Easy enough to get some made to length if you just want them extending a little. Are you wanting to mount the p/v servo further away from the engine in a special by any chance?
Post by petehodges on Oct 23, 2016 22:42:03 GMT 1
hi mark cheers for reply no mate its an lc with ypvs the pv motor is mounted above but the cables are just a bit too tight
Post by bazzer5115 on Oct 23, 2016 22:58:23 GMT 1
Had the same problem when I fitted ypvs motor in my lc. Made a lovely bracket to mount p.v. Motor but cables where a a bit short/tight fit and I wasn't happy with it. Made my own from a cable kit from venhill engineering,very helpful and knowledgeable,give them a call Baz
Post by bare on Oct 24, 2016 1:18:21 GMT 1
hi mark cheers for reply no mate its an lc with ypvs the pv motor is mounted above but the cables are just a bit too tight KEEP trying! the setup works Fine for most people :-)!
Post by markhoopy on Oct 24, 2016 11:02:19 GMT 1
If you want longer cables then +1 on making your own. Easy to do with a kit and p/v cables aren't as worrying as a DIY front brake cable every time you grab the lever
Post by mark350lc on Oct 24, 2016 14:03:18 GMT 1
I get Venhill to make mine. Just tell them inner and outer length or send originals and say x amount longer.
Post by petehodges on Oct 24, 2016 22:18:25 GMT 1
cheers all sorted went with norbo in the end
