Post by petehodges on Oct 23, 2016 10:02:26 GMT 1
Morning lads Where are you getting your petrol pipe from ? ( think it's 6 mm ) As mines got rock hard again also carb overflow pipe .i know Norbo sells it aswell but thought I'd ask the question Big thanks as allways Pete
Post by LC_BOTT on Oct 23, 2016 10:27:26 GMT 1
Post by markhoopy on Oct 23, 2016 10:55:54 GMT 1
I bought a metre of the PJME pipe last month after seeing it recommended on another thread. They also do the wire fuel line clips too and it all looks to be decent quality.
Post by Norbo on Oct 26, 2016 7:14:23 GMT 1
I do gen yam its just £3.50
phil38
Post by phil38 on Nov 25, 2016 10:30:07 GMT 1
I do gen yam its just £3.50 Is this just "off the roll" or can you get pipes with all the bends in etc. ?
Post by Shytalk on Nov 25, 2016 14:38:16 GMT 1
I do gen yam its just £3.50 Is this just "off the roll" or can you get pipes with all the bends in etc. ? It'll be off the roll, just cut the length required and fit, its not stiff enough 🤐 to be able to be pre shaped.
Post by Norbo on Nov 25, 2016 15:37:55 GMT 1
Its just a length as they come from Yamaha
Post by reggieperrin on Nov 25, 2016 21:23:06 GMT 1
Tygon is ok and I've used it in the past. I have lots of it... It doesn't tend to stay on the 'push on' parts of the carbs like overflows etc. It was never designed to be used as a pipe and as such doesn't grip very well. I have now reverted to clear fuel pipe and will just change it each year.
Post by bare on Nov 26, 2016 19:18:23 GMT 1
Bad batch of Tygon? Wrong size possibly? Tygon is V good Fueline. Has been for me. Some it over 10 years old and it retains good grip and flex qualities.
Post by 4l04ever on Nov 26, 2016 20:48:35 GMT 1
The kart fuel pipe seems good for the price, but only available in 6mm bore, which is okay for LC carbs.
Post by ozzysbikes on Nov 26, 2016 21:40:24 GMT 1
Norbo is selling genuine Yam ! why would you not use him (that) ? it's top quality, I bought mine a while back (before finding Norbo) and the length that you get is enough for two or three bikes, replaced mine and put the rest in stock (and it is as cheap as spurious stuff)
Post by reggieperrin on Nov 27, 2016 10:39:42 GMT 1
Bad batch of Tygon? Wrong size possibly? Tygon is V good Fueline. Has been for me. Some it over 10 years old and it retains good grip and flex qualities. Nope. I use lots of Tygon of various sizes, I buy 50m rolls at a time. It doesn't like staying on tapered spigots without some sort of barb. It was originally designed as an insulator for fibre optics not a fuel pipe, we're just lucky that it suits our needs.
