Post by mollers on Oct 17, 2016 15:28:05 GMT 1
Afternoon all
Help Help !!!!
Cleaning my carbs on my 4L0 and just F**king snapped off the 2 stroke oil brass input connector !!!!!
Anyone know if you can get some kind of replacement or such like
Crying in my man shed
Cheers Moller
Post by shaunthe2nd on Oct 17, 2016 15:36:53 GMT 1
The brass connector is a push fit into carb body, so you should be able to pull out or drill out the remaining bit. I'm not sure if you can buy the brass bits, i gave my spare ones away, but you can salvage them out of any other redundant LC carb bodies without too much difficulty.
Post by crash on Oct 17, 2016 17:29:02 GMT 1
Heat the carb body up a bit ,it pulls out
Post by mollers on Oct 17, 2016 17:36:52 GMT 1
Thanks guys will give it a go.
Ok so a little heat and ive got the rest of it out of the carb body.
Anyone got any ideas for a replacement bit apart from a donor carb ??
Thanks all. Chris
Post by jon on Oct 17, 2016 19:50:50 GMT 1
I could always machine you one in brass if your stuck.
Post by wangwang on Oct 17, 2016 20:02:43 GMT 1
Post by mollers on Oct 17, 2016 20:40:22 GMT 1
Thanks for the offer Jon but wangwangs little gem might be worth a go.
Thanks chaps.
Post by jon on Oct 17, 2016 21:55:15 GMT 1
Totally understand mollers.
Just depends whether you want a functional item, or one for a nut and bolt resto.
I saw a set of carbs for sale recently on eBay with one of these missing, and thought I could make one of those.
Maybe I will some day, but I've got more than enough to do!
Post by steeley on Oct 18, 2016 8:09:24 GMT 1
Post by Norbo on Oct 18, 2016 9:01:22 GMT 1
whats your address i pull one out of a second hand scrap set for you
Post by mollers on Oct 18, 2016 19:47:02 GMT 1
Thanks Steely and Norbo.
Pm sent Norbo.
