Post by lrcarl on Oct 12, 2016 20:00:33 GMT 1
Can Anyone give me the measurement between The disc surfaces on rgv front wheel please Thanks carl
Post by Yogi on Oct 12, 2016 20:41:41 GMT 1
Hi Carl Had a quick measure up Between the discs is 121mm,each disc has 14mm offsets So the hub is approx 93mm,can't get the gauge close enough to the hub to be exact It's probably 95/96mm Cheers Matt
Post by lrcarl on Oct 12, 2016 20:58:36 GMT 1
Post by lrcarl on Oct 12, 2016 21:03:44 GMT 1
Hi Matt the gsxr wheel I got is 92mm Just got another 'rgv'wheel today 89mm Same as the last one I got Thought gsxr and rgv where same and all Model rgv same
Post by midlifecrisisrd on Oct 12, 2016 22:08:48 GMT 1
Check the bearing diameters too
Mine was 600 mk1 bandit and was 89mm so I had to make spacers.
Bandit ran smaller axle and speedo drive end of hub is different
Post by Yogi on Oct 12, 2016 22:18:27 GMT 1
I'm pretty sure I swapped parts from one to another with no probs But don't take it as gospel it was a while ago
Post by lrcarl on Oct 12, 2016 22:26:15 GMT 1
Check the bearing diameters too Mine was 600 mk1 bandit and was 89mm so I had to make spacers. Bandit ran smaller axle and speedo drive end of hub is different Steve Bearings same as rgv centre spacer smaller on mine Carl
Post by lrcarl on Oct 12, 2016 22:35:05 GMT 1
I'm pretty sure I swapped parts from one to another with no probs But don't take it as gospel it was a while ago Had a look on rgv forum All year rgv same Straight swop gsxr 400gk76 More feckingspacers Carl
Post by lrcarl on Oct 13, 2016 8:19:14 GMT 1
I'm pretty sure I swapped parts from one to another with no probs But don't take it as gospel it was a while ago Had a look on rgv forum All year rgv same Straight swop gsxr 400gk76 More feckingspacers Carl Can anyone confirm this before I rip into the seller Messaged him before purchase said 100%rgv Thanks carl
Post by midlifecrisisrd on Oct 13, 2016 8:42:27 GMT 1
I've had vj21, vj22, and gk76 front wheels and they were all the same (the rgv wheels were complete front ends so original and proven rgv)
If the disc spacing is 3mm narrower and the centre spacer is 10mm narrower then it's not an rgv wheel.
Many 99''s Suzuki''s had this spoke and disc bolt pattern so could be from anything
Post by lrcarl on Oct 13, 2016 9:21:50 GMT 1
I've had vj21, vj22, and gk76 front wheels and they were all the same (the rgv wheels were complete front ends so original and proven rgv) If the disc spacing is 3mm narrower and the centre spacer is 10mm narrower then it's not an rgv wheel. Many 99''s Suzuki''s had this spoke and disc bolt pattern so could be from anything Steve Thanks Steve
