Post by muzz350 on Oct 3, 2016 12:37:13 GMT 1
Just a bit of help needed with price for blasting some crankcases - been quoted £70 for them doing upper and lower - is that a good price ? Cheers Muzz
Post by Yogi on Oct 3, 2016 12:39:43 GMT 1
I payed £50 for cases,head and barrels then £20 for the carbs Does sound a tad expensive Matt
Post by rostrumorhospital on Oct 3, 2016 12:40:44 GMT 1
I got mine done a few weeks back and for a twin cylinder it was 35-40 quid, triples and 4 cylinders are more, That was East Antrim Vapour Blasting in N.Ireland
Post by mark350lc on Oct 3, 2016 14:53:00 GMT 1
For your reference, I would be charging £50 for upper and lower cases.
Post by muzz350 on Oct 3, 2016 15:39:59 GMT 1
maybe not to bad then - its local and I have to drop them in - thanks for all the replies.
Post by markhoopy on Oct 3, 2016 15:54:47 GMT 1
When you get your cases back from vapour blasting give them a good was down with a hose pipe. You will be surprised how much of the blasting media is still hidden away in nooks and oilways etc!
Post by sbscnor on Oct 3, 2016 16:00:47 GMT 1
For your reference, I would be charging £50 for upper and lower cases. Mark has done loads of stuff for me always good service and fast turn around time.
Post by jon on Oct 4, 2016 7:22:38 GMT 1
Just for reference I paid £60 for upper and lower cases.
I thought this was a little steep compared to other prices, however it was local, so you have to factor in postage charges (and possible damage in post!)
Post by dusty350 on Oct 4, 2016 7:29:57 GMT 1
I pay £50 for crank cases. Put bolts in all threadways first to help keep media out. Still rinse really well afterwards though.
Dusty
Post by muzz350 on Oct 4, 2016 8:13:48 GMT 1
so sounds like they could do with a good ultrasonic clean afterwards then?
Post by markhoopy on Oct 4, 2016 9:56:16 GMT 1
You would need a fair size ultrasonic cleaner but if you have one then you may as well use it. Thoroughly washing with water would be ok though.
Post by paulsx on Oct 4, 2016 11:25:38 GMT 1
Paid £40 for a company in the Midlands to it. Blanked all bolt holes first, then put in dishwasher with no detergent.
Post by muzz350 on Oct 4, 2016 12:27:52 GMT 1
I am fortunate to have a big ultrasonic cleaner so that should be no problem its just the worry about how aggressive it is on gasket faces ect.
Post by markhoopy on Oct 4, 2016 13:37:05 GMT 1
Vapour blasting and a good rinse is all you need to do. They do come out really well ..
Post by 4l04ever on Oct 4, 2016 17:37:23 GMT 1
Kev at Projex in Cradley Heath does a good job and will do you a good price....
Post by jon on Oct 4, 2016 20:01:17 GMT 1
Mark, my pv cases also came up well. Would be a sin in my opinion to paint the top half.
If you were going for a nut and bolt resto, and wanted to paint the top half, then the bottom wouldn't look original anyway, as after they are vapour blasted the finish is literally better looking than original.
Post by hondasp1 on Oct 11, 2016 17:06:08 GMT 1
cre motorsport in west yorkshire has just set up vapour blasting.
