Post by dangerousal on Sept 29, 2016 8:54:34 GMT 1
Hi All,
I just joined and am embarking on my first hybrid project. I have a 31k ypvs and am looking at doing front end, rear end and engine upgrades.
I have owned 4 ypvs 350's in the past, but not for 25 years! and just bought another one
Last year i did a complete nut and bolt build of a triumph t595 with a 2005 engine, and 1050 s3 usd front end
Any advice on
zxr400 front end
and back end conversions.....which back ends are simplest, cost effective, and effective?
Looking for a decent set of pipes ( not oem )
Any help would be greatly appreciated
Post by dusty350 on Sept 29, 2016 9:00:07 GMT 1
Hi Welcome to the forum mate Mouse is just embarking on the same project and has collected a lot of parts already so could be worth speaking to him. Also, look through the resto section on here - lots of info and ideas Enjoy Regards Dusty
Post by mouse on Sept 29, 2016 9:03:53 GMT 1
Hi Welcome to the forum mate Mouse is just embarking on the same project and has collected a lot of parts already so could be worth speaking to him. Also, look through the resto section on here - lots of info and ideas Enjoy Regards Dusty Yes, give me a shout if i can help Mouse
Post by markhoopy on Sept 29, 2016 9:46:41 GMT 1
Welcome to the forum! Once you reach ten posts you will have access to the Classifieds section which you should find useful. TSA pipes are popular but you will need to book in early if you want some making as Kenny is a very busy man
Post by twostrokejoe on Sept 29, 2016 9:51:08 GMT 1
Welcome to the forum. The lads on here are very helpful. Enjoy 😀
Post by dangerousal on Sept 29, 2016 12:25:45 GMT 1
Hi Welcome to the forum mate Mouse is just embarking on the same project and has collected a lot of parts already so could be worth speaking to him. Also, look through the resto section on here - lots of info and ideas Enjoy Regards Dusty Yes, give me a shout if i can help Mouse Hi mouse...thanks for that....so which front and rear ends are you using?
Post by mouse on Sept 29, 2016 13:14:16 GMT 1
Going to be using RGV250 VJ22 with the 'Banana' swingarm
Post by Norbo on Sept 29, 2016 13:21:17 GMT 1
if you havent all ready got one i would look at something elce for the swinging arm , they are so common now on valves and lcs look for something different and make it stand out more
Post by Yogi on Sept 29, 2016 13:43:24 GMT 1
Welcome mate I've just done rs250 front and rear Lots of options my lc2 with Rgv,vj22 rear and gsxr400 front Your call Matt
Post by rostrumorhospital on Sept 29, 2016 15:21:26 GMT 1
Welcome, good luck & enjoy!
Post by Eyrey1 on Sept 29, 2016 17:11:15 GMT 1
if you go rs250 ive got a compete mk2 rs250 front end im taking it off my 500 as i have ohlins now also got the rear wheel complete both wheels are brembo on mk2 and front is bigger than mk1
not cheap though but only done 3000 miles from new also got brembo goldline calipers and break lines all in very good very clean condition
Post by dangerousal on Sept 29, 2016 21:44:24 GMT 1
I'm not too bothered about it being unique...although it will be of course...so I got hold of a vj22 swing arm...anyone got patterns for parts needed to make it work,..do you need a different shock?
Post by Yogi on Sept 29, 2016 22:27:58 GMT 1
You can buy a kit from Nkracing £125 for banana arm type £225 for braced arm You can then use the Rgv shock as the spacers are in the kit Matt
Post by Tobyjugs on Sept 29, 2016 22:59:03 GMT 1
Good luck with your build
Post by markhoopy on Sept 29, 2016 23:44:29 GMT 1
Post by dangerousal on Sept 30, 2016 7:41:40 GMT 1
Thanks for that...the PDF link is broken unfortunately...do you have an alternative source?
Post by markhoopy on Sept 30, 2016 19:22:22 GMT 1
Thanks for that...the PDF link is broken unfortunately...do you have an alternative source? LC_BOTT has commented on the thread with a link to the pdf
Post by TZ750D on Oct 4, 2016 8:27:09 GMT 1
Welcome mate I've just done rs250 front and rear Lots of options my lc2 with Rgv,vj22 rear and gsxr400 front Your call Matt Very nice!
Post by Mr Kipling on Oct 6, 2016 0:09:28 GMT 1
Welcome aboard , enjoy the build ,
