Post by doohanno1 on Sept 21, 2016 22:33:51 GMT 1
but....I was rebuilding a 4l0 engine this evening and was about to install the small ends tthat came with the refurbed crank.." Hold on i says" i have some oem ones somewhere...Well theres some difference..I am now going to use the supplied ones as tambourines..!!! You can"t beat oem...
Post by Ozhammer on Sept 22, 2016 7:31:24 GMT 1
OEM beats pattern 99 times out of a 100 in my experience. I only use patern parts for non-critical items, or where the expense or non-availability of OEM dictates.
You should name and shame the supplier so as to warn other forum members off making the same mistake.
Rgds Ozhammer
Post by arrow on Sept 22, 2016 9:38:28 GMT 1
I have also wondered how many people out there are using 250 small ends in the 350 motor??
Post by Norbo on Sept 22, 2016 9:54:53 GMT 1
Bearin mined that yam aha dont make anythging so KOYO bearings are OEM TKR pistons are OEM Ric rings are OEM Long rods are OEM
so some times its not being in a yam bag that's impotent lots of stuff made in japan are OEM items so to speak if you see what im getting at .
Its some of the pattern stuff thats remade to replace oem stuff you have to look out for .
Post by doohanno1 on Sept 22, 2016 22:51:55 GMT 1
OEM beats pattern 99 times out of a 100 in my experience. I only use patern parts for non-critical items, or where the expense or non-availability of OEM dictates. You should name and shame the supplier so as to warn other forum members off making the same mistake. Rgds Ozhammer In fairness i don"t think its about nameing and shameng..I was aware that it was not buying genuine parts and i am sure that the small ends would have done the job.... Its a different matter when you buy a spurious part and the bloody thing doesn"t even fit...
Post by markhoopy on Sept 22, 2016 23:12:42 GMT 1
Its a different matter when you buy a spurious part and the bloody thing doesn"t even fit... Naming and shaming Yambits is fair game I think
Post by doohanno1 on Sept 22, 2016 23:24:19 GMT 1
Its a different matter when you buy a spurious part and the bloody thing doesn"t even fit... Naming and shaming Yambits is fair game I think you said it not me..
Post by Eyrey1 on Sept 22, 2016 23:59:20 GMT 1
Its a different matter when you buy a spurious part and the bloody thing doesn"t even fit... Naming and shaming Yambits is fair game I think now thats out of order ! yam bits are great lol bad man mark .
Post by lolly on Sept 24, 2016 9:06:53 GMT 1
I have used yambits about 7 times for non critical items and found them ok ; I even bought some carb manifold rubbers and carb repair kits and appear to be ok ?
I suppose I will now have my epilates ripped off ; my sword snapped and expelled LOL
Post by billbott on Sept 24, 2016 9:23:10 GMT 1
I used pattern small ends when I rebuilt my 350. Never again. After 800 easy miles they failed.
Post by markhoopy on Sept 24, 2016 11:06:28 GMT 1
I've used them too - gear lever rubber, inline fuse, tab washer etc .. fast delivery (but all sent recorded so not cheap) and a big range too. The bad reputation is for seals, bearings, and all things important
Post by stusco on Sept 24, 2016 12:21:33 GMT 1
I've just paid £42 for two gen ypvs small ends from fowlers I now feel I've had my pockets picked
Post by markhoopy on Sept 24, 2016 12:28:01 GMT 1
I've just paid £42 for two gen ypvs small ends from fowlers I now feel I've had my pockets picked Cheaper than buying pattern ones and ending up needing a rebore and new pistons though
Post by spondonchris on Sept 24, 2016 14:18:19 GMT 1
Makes me laugh this OEM haha. Yamaha dont make em. The ones from Grampian are just fine, KOYO bearings are brilliant too. Stuff like Cables i always buy Yamaha. Thinking you need small ends with Yamaha on the bag is ridiculous.
Post by doohanno1 on Sept 24, 2016 22:35:28 GMT 1
Makes me laugh this OEM haha. Yamaha dont make em. The ones from Grampian are just fine, KOYO bearings are brilliant too. Stuff like Cables i always buy Yamaha. Thinking you need small ends with Yamaha on the bag is ridiculous. So who makes the cables , Yamaha.. Watch where your pointing your gun , you nearly shot yourself in the foot... So maybe when we talk about oem we should say " to oem standard "...
Post by doohanno1 on Sept 24, 2016 22:41:36 GMT 1
I used pattern small ends when I rebuilt my 350. Never again. After 800 easy miles they failed. Can you say who supplied them..
justyr
Post by justyr on Sept 25, 2016 7:40:53 GMT 1
Practical sportsbikes is being supplied by yambits to do their tdr rebuild. Let's see if anything untoward is reported. It'll be a hoot if they supply them with their crank seals.
Post by billbott on Sept 25, 2016 9:12:40 GMT 1
I used pattern small ends when I rebuilt my 350. Never again. After 800 easy miles they failed. Can you say who supplied them.. I think it was 'scooters and bikes' on eBay..... As an aside, I rebuilt it (new crank, barrel, two pistons and a head....) and used little ends from yamaha and it's run perfect since on the same set up, over 3000 miles.....
