Post by mattybeckett on Sept 19, 2016 15:44:15 GMT 1
Fitted a brand new yambits throttle cable a while ago and balanced slides and only just had enough adjustment left on the thread to get oil pump marks lined up. Can't seem to get enough free play for slides, when i slack off to put some play at throttle the oil pump marks dont line up. just can't seem to get it how it should be, i guess the cables aren't the best and wondering if any other good patern ones out there, if not it looks like iv'e got to get a genuine cable.. Cheers.
Post by Deleted on Sept 19, 2016 16:19:44 GMT 1
They are crap......
Get a genuine one...
Post by mattybeckett on Sept 19, 2016 22:20:11 GMT 1
Hi 14Cheeks, thanks for reply' could you advise me where you purchased your genuine yamaha cable and how much/price? have you tried one of the yambits cables which you described as crap.. and did you have the same problems? Cheers.
Post by sp885 on Sept 20, 2016 4:24:42 GMT 1
Get one of Norbo's OEM quality ones, I've had mine on for about a year now, no problems Steve
Post by arrow on Sept 20, 2016 8:01:52 GMT 1
Yes, get one from Norbo. It will over oil a lot in the lower to mid range with a pattern cable. Seen it a good few times now.
Post by muttsnuts on Sept 20, 2016 13:59:41 GMT 1
taken loads of yambits cables off and replaced with genuine ones for customers, its just not worth it, just bite the bullet and buy a genuine one, or as others have said, try one of Norbo's as not heard any bad reports about them
Post by muzz350 on Sept 20, 2016 14:09:55 GMT 1
only use if running premix!!!
Post by yamark on Sept 20, 2016 18:39:32 GMT 1
Another endorsement for Norbo's throttle cable. AFAIK they are identical in measurement to the gen Yam ones. Norbo's one fitted perfectly.
Post by mattybeckett on Sept 20, 2016 20:23:50 GMT 1
Would be nice and easy if norbo's shop had a buy it now option or add to basket and do a big shop without complications.
