Post by 4l04ever on Sept 19, 2016 15:32:59 GMT 1
Any recommended?
The last lot I got from the Stafford show loses flexibility when fuel has gone through it.... Okay for water hoses, but that is all.
Post by steven on Sept 19, 2016 15:47:14 GMT 1
Post by shaunthe2nd on Sept 19, 2016 16:18:21 GMT 1
Sorry to jump the thread, but i am after some too, both petrol and oil pipe. Do you know if the petrol is the 5mm bore x 8mm outer, and the oil is the 3mm/5mm one?
Post by 4l04ever on Sept 19, 2016 16:28:41 GMT 1
I think LC's have a funny size for fuel pipe. Is the correct tube 5.5mm ID? Just measured 4L0 carb inlet - 6mm OD, so 5.5mm would be a better fit than 6mm tube.
Post by steven on Sept 19, 2016 16:39:55 GMT 1
.... I used the 6.5 x 11 purple stuff, fits fine. I found appropriate clips for it all on ebay, but not standard ones. Sorry Shaun, no idea about the oil pipe, as I run premix.
Post by arrow on Sept 19, 2016 16:43:04 GMT 1
I have just started stocking the Ariete pipe in 32" lengths for the tank to pump, and decent clips too. 6mm bore, 9mm od.
Post by Yogi on Sept 19, 2016 16:48:35 GMT 1
I have just started stocking the Ariete pipe in 32" lengths for the tank to pump, and decent clips too. 6mm bore, 9mm od. Don't be shy,tell us more
Post by arrow on Sept 19, 2016 16:49:46 GMT 1
I have just started stocking the Ariete pipe in 32" lengths for the tank to pump, and decent clips too. 6mm bore, 9mm od. Don't be shy,tell us more What more do you need to know Sir?
Post by Yogi on Sept 19, 2016 16:53:39 GMT 1
How many sheckles a length + clips young man
Post by arrow on Sept 19, 2016 16:57:30 GMT 1
Two prices. £7.50 if it comes back with a pump and £8.50 if it travels alone. Its funny stuff. Not like neoprene or rubber, more like a very flexible plastic. It looks like it will have a long life, 'sposed to be the best stuff. The clips are double loop wire. The best IMO.
Post by steven on Sept 19, 2016 16:58:36 GMT 1
... Here is a pic of the 6.5 x 11 purple stuff fitted with the clips I found on ebay, obviousely Elsie still had her yellow clothes on three years ago. I think they only did the purple stuff at the time I was looking for it, so mabey the 5.5 stuff will be a tighter fit, Iv had no probs with any leaks or anything so far with the 6.5 stuff and those clips. cheers, steven.
Post by Yogi on Sept 19, 2016 17:01:12 GMT 1
Two prices. £7.50 if it comes back with a pump and £8.50 if it travels alone. Its funny stuff. Not like neoprene or rubber, more like a very flexible plastic. It looks like it will have a long life, 'sposed to be the best stuff. The clips are double loop wire. The best IMO. I'll have some sent back with my next pump as it will be for the same bike Is it the normal green colour and are the clips extra or included? Matt
Post by arrow on Sept 19, 2016 17:02:42 GMT 1
Nice pic Steven, cheers. I only intend to stock the black.
Post by arrow on Sept 19, 2016 17:05:37 GMT 1
Two prices. £7.50 if it comes back with a pump and £8.50 if it travels alone. Its funny stuff. Not like neoprene or rubber, more like a very flexible plastic. It looks like it will have a long life, 'sposed to be the best stuff. The clips are double loop wire. The best IMO. I'll have some sent back with my next pump as it will be for the same bike Is it the normal green colour and are the clips extra or included? Matt Black only. Price is with the clips. 32" is enough for the lc and ypvs bikes, and may need to be trimmed to length.
Post by Yogi on Sept 19, 2016 17:10:23 GMT 1
I'll have some sent back with my next pump as it will be for the same bike Is it the normal green colour and are the clips extra or included? Matt Black only. Price is with the clips. 32" is enough for the lc and ypvs bikes, and may need to be trimmed to length. Sweet I wanted black as its gonna be an lc2 resto Be in touch soon
Post by arrow on Sept 19, 2016 17:11:59 GMT 1
Ok, cheers Matt.
Post by muttsnuts on Sept 19, 2016 18:46:48 GMT 1
Shaun, if you pop round I have some geunine Yam oil pipes (pump to carbs) and clips and decent fuel pipe if your after some, also have some purple ariete pipe left and some other stuff which so far has proven to be good, also got clips etc of course
Post by headcoats on Sept 19, 2016 19:55:02 GMT 1
Black don't crack, er yes it does LOL
Post by shaunthe2nd on Sept 19, 2016 20:31:58 GMT 1
Shaun, if you pop round I have some geunine Yam oil pipes (pump to carbs) and clips and decent fuel pipe if your after some, also have some purple ariete pipe left and some other stuff which so far has proven to be good, also got clips etc of course Thanks Dave, PM sent
Post by fifty50 on Sept 19, 2016 21:28:54 GMT 1
Post by Norbo on Sept 20, 2016 9:57:17 GMT 1
I fined a length of gen yam is best . ive tried lots and not for fuel line and oil line do gen yam
Post by 4l04ever on Sept 20, 2016 10:35:58 GMT 1
Yes, OEM Yamaha/Honda/Suzuki/Kawasaki seems to last a lot better than any aftermarket products. Will have to find the best value OEM stuff.
