Post by headcoats on Sept 9, 2016 20:07:43 GMT 1
Anyone used these 34's I guess
Post by JonW on Sept 9, 2016 23:09:47 GMT 1
I have a 36 pumper on my XT500, its a great unit, but never considered em for the 2 strokes as its quite tall.
Post by Eyrey1 on Sept 10, 2016 1:35:12 GMT 1
6ive had them on tzr250 3xv sp are 36mm or spr are 32mm shape r model is 28mm they are really good carbs on any bike ive not read anything bad about them
Post by bazzer5115 on Sept 10, 2016 9:14:18 GMT 1
I've got mikuni tm32 on one ypvs hybrid and mikuni tmx35 on another. No problems and easy to set-up/jet. Baz
Post by headcoats on Sept 10, 2016 9:17:46 GMT 1
Baz do you need different inlet rubbers etc
What about the height like mentioned above ?
After years of PWK 28 carbs I just fancy a change as I have never got them to fuel right , especially lower revs They made good power but would like to try something different as a comparison
I know some folks took them off altogether
Post by somethingelsie on Sept 10, 2016 22:01:52 GMT 1
Martin I've got a pair on me 421 34's too. Atb Lee
Post by bazzer5115 on Sept 10, 2016 22:37:37 GMT 1
Yeah you do need new inlets,for 2 reasons. First reason is that carbs are taller and float bowl on left carb will foul clutch operating arm on ypvs engine. Secondly the inlet stub is to big to fit standard inlet rubbers. I run the alloy inlets with v-force reeds,on these inlets you can specify what size rubber will fit your inlet stub. Also you will need to run pod filters as the air intake side is also bigger.But does really make carb removal for jetting really simple.The dimensions of these carbs are on the "allens performance " website. Then of course you will need to make custom length throttle cables.I made mine from a kit from venhill engineering ,but I also run a domino quick action twin pull throttle with no splitter box as I run premix. So as usual with so many modifications,one thing leads to another,but it all worth it in the end!😄
Post by yazza54 on Sept 12, 2016 20:00:32 GMT 1
I run TMX 38s and have found them to be decent carbs just a shame the needle literature is a little more complicated than the Keihins
