Post by petehodges on Sept 9, 2016 6:47:04 GMT 1
Hi lads as above Bought new black washers from Yamaha for this but still seems to be leaking down the threads it's a pv tap on Lc tank . Any advice on this would be great cheers
Post by Trubrit on Sept 9, 2016 7:01:40 GMT 1
I Always Put A Bit Of Yambond/Threebond On The Screws & Try To Keep The Petrol Away While It Goes Off A Bit
Dave
Post by Norbo on Sept 9, 2016 9:02:04 GMT 1
good advice as it can pass by the threads
Post by rigga on Sept 9, 2016 10:05:33 GMT 1
I put a o ring on each bolt, stopped my leaks.
Post by critchlg on Sept 9, 2016 14:20:35 GMT 1
Had the same issue last week. Put some fuel resistant gasket sealer on the threads. Let it go off a bit then put them back in. Works so far.
Post by seanclarky on Sept 9, 2016 15:10:46 GMT 1
i put fibre washers on and that fixed it for me
Post by headcoats on Sept 9, 2016 23:01:32 GMT 1
i put fibre washers on and that fixed it for me Ditto
I just can't turn the feckin tap now
Post by bazzer5115 on Sept 10, 2016 9:10:29 GMT 1
+1 for fibre washers.
Post by oldelsieboy on Sept 10, 2016 10:16:38 GMT 1
I always fit genuine bolts & washers & never had any leaks.
OEB
Post by bare on Sept 12, 2016 4:42:07 GMT 1
Hmmm I too fit gen New fibre washers .. still seeped fuel .. Grrr. Put Threebond on the screw threads and the problem hasn't resurfaced... in 6 years use.
Post by petehodges on Sept 12, 2016 21:32:06 GMT 1
cheers lads got some threebond off norbo in the end hes not a bad lad after all
