Post by petehodges on Aug 14, 2016 22:36:07 GMT 1
Hi all As above I'm a bit green with this so I'll give you the low down . Stripped barrels off sent up too Mick abbey meanwhile been looking at the Pistons there 0.25 so I've never changed the rings since I've owned it spoke with Mick & he advised to put a new set in , so I've now got the barrels back & got my new 0.25 rings So how do I check there ok in the bores as I don't want too fook them up Any advice on this would be great Cheers Pete
Post by arrow on Aug 14, 2016 22:42:29 GMT 1
Push the rings up square in the bore from the bottom with the piston, (rings fitted from the top) 10mm down from the top will be fine. Use a diamond tipped file if you need to make adjustments to the gap, but most are ok.
Post by petehodges on Aug 14, 2016 22:49:11 GMT 1
Thanks arrow but what sort of gap am I looking for ?
Post by arrow on Aug 14, 2016 23:06:45 GMT 1
I don't know the specs. off by heart, but someone on here will know.
I have them on the main computer, but i'm sat in the pub on the tablet!
Post by bare on Aug 15, 2016 17:43:18 GMT 1
OEM yama rings are Always oversize in ring gaps .. they never meet the yama specs. No Idea why . That said: OEM rings are a MUCH better choice ... given the opprtunity :-)
Post by LC_BOTT on Aug 15, 2016 19:19:20 GMT 1
Got my 31K Yam manual (similar to Haynes) it has....
top ring (350) min 0.3mm max 0.45mm (12-18 thou)
bott ring min 0.3mm max 0.5mm (12-20 thou)
Post by stusco on Aug 15, 2016 19:57:47 GMT 1
Got my 31K Yam manual (similar to Haynes) it has.... top ring (350) min 0.3mm max 0.45mm (12-18 thou) bott ring min 0.3mm max 0.5mm (12-20 thou) Same as in Haynes ,but are they correct nobody seems to be able to agree
Post by LC_BOTT on Aug 15, 2016 21:17:19 GMT 1
Well if that's the case, who do you believe? best to call a two stroke specialist or tuner, and see what they use.
Post by bare on Aug 16, 2016 3:55:02 GMT 1
Ring end gap ONLY matters when one buys/fits low quality aftermarket rings... that actually don't seal near as well as oem Yama ones.. under any circumstance Buy Cheap.. buy repeatedly.
