Post by noonster on Aug 6, 2016 21:26:42 GMT 1
I have recently bought a rd250f and working through the issues.
Got the bike running,
It revs and goes but the excellaration responsponce is poor,
Looking at the carbs i have noticed i can't get the dot to appear in the carb windows,i have adjusted the cable screws but still can't get them yo appear.
if i lift the cable a little above the screw on the the carb top the dot appears.
Shouls i try another throttle cable from norbo or am i missing something.
chris
Post by howard on Aug 6, 2016 22:24:55 GMT 1
Are you comparing it to your 400 and LC because a 250 it totally different it needs its neck ringing to keep it buzzing ,
Post by paulsx on Aug 12, 2016 22:22:04 GMT 1
You need to adjust them more. I had this with mine you need to use the adjuster at the twist grip end to take some of the slack out and then go from there. I've got one of norbo cables and it's ok, the adjusters are a long way out thou
