Post by muzz350 on Jul 15, 2016 19:50:26 GMT 1
Just come to fit my paintwork for the first time and fastened on the fuel tap to find threads gone! It was fine before but something has gone seriously wrong,i managed to pass through some bolts from the inside of the tank and use them as studs but fuel leaking down thread! Looks like I will have to try a sealing washer inside the tank unless anyone can suggest anything else or take it out to M8 if anyone has tried this? Off to drown sorrows 😥 Muzz
Post by midlifecrisisrd on Jul 15, 2016 20:03:50 GMT 1
That's a nightmare
Just fitted mine to the new bodywork and was cringing tightening them just in case it went wrong
Best you can do is order 4 of the rubberised washers that go on the screws and fit them inside and out.
That should sort it
Post by unrealedd on Jul 15, 2016 20:08:27 GMT 1
can you not try a threadsert or helicoil i think thats what i would have a crack at!! feel your pain bud.
Post by muzz350 on Jul 15, 2016 20:37:03 GMT 1
Yes thinking about rubber washer in tank and a small o ring on outside tank then fit the tap - had the bodywork done about 3 years ago but been running it in different colours but we'll pissed off!
Post by arrow on Jul 15, 2016 20:37:41 GMT 1
What's happened there then? Does a correct size bolt pass straight through or are the threads full of paint?
Post by muzz350 on Jul 15, 2016 20:42:44 GMT 1
It was fine before paint but think it's been acid dipped or something seems that it was only paint on the threads as the bolts passed through from the inside with just a wiggle tank is the original one and it's not had that much use.
Post by arrow on Jul 15, 2016 20:44:03 GMT 1
There is a way to fix this, just come to me now.
Post by muzz350 on Jul 15, 2016 20:46:43 GMT 1
Blank it and syphon from top!!!!
Post by arrow on Jul 15, 2016 20:51:37 GMT 1
If you make up a small piece of plate with a cutout for the filter bit to go through and two nuts braized on at the correct centers that could go inside the tank? An assistant with a bent coat hanger would help during fitting.
Post by muzz350 on Jul 15, 2016 20:56:50 GMT 1
I thought about something like that but cannot even see the tap hole from the fuel cap - good job I work in a hospital I can borrow some gynaecologist instruments!
Post by paulturnbull on Jul 15, 2016 20:57:29 GMT 1
the bolt heads will need sealing washers ,should seal wether inside or out ,but must be on bolt head not nut
Post by arrow on Jul 15, 2016 21:03:16 GMT 1
I thought about something like that but cannot even see the tap hole from the fuel cap - good job I work in a hospital I can borrow some gynaecologist instruments! So you got the bolts coming from the inside by wiggling the via the small rectangular hole?
Post by muzz350 on Jul 15, 2016 21:12:29 GMT 1
Yes I used a small strong magnet on a Allen key and got them through that way there cannot be much good thread left, so will try again in the morning with hopefully a clear mind, I am going to try get a washer on in side then a small o ring on outside and cross my fingers . It never even occurred to me this might happen but hopefully once it's sealed that should be it as don't really fancy helicoid or taking it to 8 mm
Post by arrow on Jul 15, 2016 21:15:30 GMT 1
Make up the plate with two nuts on. Fit it through the rectangular hole. Hold in place with two lengths of threaded bar. Then change one at a time with the correct bolts. Sorted.
Post by muzz350 on Jul 16, 2016 15:48:02 GMT 1
Well lot happier today! Had another go and a combination of rubber seals on inside o rings on outside with bolts through from inside tank and it's back on bike and holding fuel so fingers crossed back on road next week😀 thanks for all help and suggestions.
