Post by headcoats on Jul 15, 2016 12:53:35 GMT 1
Are they the same or different and will say a YPVS gear lever fit an LC ?
Post by midlifecrisisrd on Jul 15, 2016 13:12:37 GMT 1
I thought they were different but someone said the other week they had fitted an Lc pedal to a ypvs.
Rods are different lengths.
Repro Lc set up available and later ypvs ( not chrome)
Luckily I bagged a nos 29l ypvs one for 20 quid☺
Post by oldelsieboy on Jul 15, 2016 13:25:00 GMT 1
The length of the pivot shaft is different, LC is longer than YPVS So, in theory a YPVS will fit an LC, with a spacer, but an LC will not fit a YPVS. OEB
Post by midlifecrisisrd on Jul 15, 2016 13:59:36 GMT 1
The length of the pivot shaft is different, LC is longer than YPVS So, in theory a YPVS will fit an LC, with a spacer, but an LC will not fit a YPVS. OEB It will if you get the grinder out 😈 Steve
Post by headcoats on Jul 15, 2016 14:02:57 GMT 1
Well a spacer it is then
Thanks for the pic , explains it perfectly
Is it possible to measure the difference for me ?
Post by oldelsieboy on Jul 15, 2016 14:05:42 GMT 1
The length of the pivot shaft is different, LC is longer than YPVS So, in theory a YPVS will fit an LC, with a spacer, but an LC will not fit a YPVS. OEB It will if you get the grinder out 😈 Steve Butcher OEB
Post by midlifecrisisrd on Jul 15, 2016 14:08:09 GMT 1
Excuse my possible stupidity as not owned an lc but how is it attached to the bike
Can you fit a ypvs pivot bolt to an lc?
All insults for my stupidity welcome
Nigel will no doubt have a picture showing me as an idiot.😜
Post by oldelsieboy on Jul 15, 2016 15:38:35 GMT 1
Excuse my possible stupidity as not owned an lc but how is it attached to the bike Can you fit a ypvs pivot bolt to an lc? All insults for my stupidity welcome Nigel will no doubt have a picture showing me as an idiot.😜 Steve Am I that predictable The lever is held on the pivot shaft with a washer & circlip. OEB
Post by midlifecrisisrd on Jul 15, 2016 16:04:06 GMT 1
Excuse my possible stupidity as not owned an lc but how is it attached to the bike Can you fit a ypvs pivot bolt to an lc? All insults for my stupidity welcome Nigel will no doubt have a picture showing me as an idiot.😜 Steve Am I that predictable The lever is held on the pivot shaft with a washer & circlip. OEB Not predictable nigel, just a wealth of knowledge and pictures If the pivot bolt is m10 x 1.25 then can you use a ypvs bolt on an lc and vice versa? Steve
Post by oldelsieboy on Jul 15, 2016 16:08:10 GMT 1
Am I that predictable The lever is held on the pivot shaft with a washer & circlip. OEB Not predictable nigel, just a wealth of knowledge and pictures If the pivot bolt is m10 x 1.25 then can you use a ypvs bolt on an lc and vice versa? Steve The pivot is a press fit into the footrest mounting plate & secured behind with a circlip. OEB
Post by midlifecrisisrd on Jul 15, 2016 18:16:45 GMT 1
Another helpful picture
Cheers
