Post by petehodges on Jul 11, 2016 10:19:42 GMT 1
Hi all Running 31k motor & carbs in Lc so I've got pv fuel tap on it Since my tank is now full of crap (don't use petseal !) My fuel tap has only even worked in one position ! No reserve at all It's fairly new new & not got crap on it as I've had it apart ? What's the score what positions should they work on Cheers Pete
Post by fatfastroger on Jul 11, 2016 10:23:00 GMT 1
Up is reserve, down is on and 9 o clock is prime. You are using the vac take off too ? You'll only get flow in RES or ON if you have vac. Prime will just flow constant.
Post by 4l04ever on Jul 11, 2016 11:02:39 GMT 1
You can run an LC tap and blank off the vacuum pipe on the one carb.
Post by petehodges on Jul 13, 2016 22:58:14 GMT 1
Up is reserve, down is on and 9 o clock is prime. You are using the vac take off too ? You'll only get flow in RES or ON if you have vac. Prime will just flow constant. ahh thats why it don't work its on vac thanks for that yer its vac pipe straight off the carb
