Post by markrn2710 on Jun 4, 2016 10:55:04 GMT 1
Hi thanks for letting me join the forum. Need to alter Lc2 wiring harness to except f1 clocks with electronic tacho. Any advice or tips greatly appreciated.thanks
Post by Deleted on Jun 4, 2016 13:32:28 GMT 1
There will be more knowledgeable people on here than me, however I think you will need a different stator/rotor/cdi as well as possibly removing the gear drive for the mechanical tacho and blanking off the hole
Post by kosaprasa on Jun 4, 2016 14:24:51 GMT 1
no problem, just grey wire conect to orange wire and Will Works, on Picture you can see that.
Post by unrealedd on Jun 4, 2016 14:53:15 GMT 1
no problem, just grey wire conect to orange wire and Will Works, on Picture you can see that. Nice one Kosa ;-)
Post by midlifecrisisrd on Jun 4, 2016 16:13:40 GMT 1
Is orange not the coil trigger?
I've always connected the grey tachograph wire to the trigger wire from the cdi to the pv controller
Think it's black/yellow from memory.
Will be on the diagram. If you look at f1 diagram that's where it goes on the f1. Just replied ate on the lc2
Mine runs like that (lc2 loom, F1/2 elec tacho)
Post by Yogi on Jun 4, 2016 16:48:18 GMT 1
Is orange not the coil trigger? I've always connected the grey tachograph wire to the trigger wire from the cdi to the pv controller Think it's black/yellow from memory. Will be on the diagram. If you look at f1 diagram that's where it goes on the f1. Just replied ate on the lc2 Mine runs like that (lc2 loom, F1/2 elec tacho) Steve +1 that's how I wired my lc2 hybrid Matt
Post by kosaprasa on Jun 4, 2016 16:51:38 GMT 1
it is the same, orange or black/yellow, bouth wires gives pulse
Post by KevtheRev on Jun 4, 2016 16:52:41 GMT 1
Great feckin' tips on here ! Keep it up lads .
