Post by headcoats on May 23, 2016 20:36:41 GMT 1
Is it possible to fit LED bulbs in the standard LC indicator pods
Post by bare on May 23, 2016 21:07:00 GMT 1
Dunno never tried TBH. Reg Bulbs are enough trouble. That said, local autoparts shops sell exact replacement (same bases,same overall dimensions as the reg bulbs) LED bulb things. For increasingly affordable prices.
Post by rigga on May 23, 2016 21:33:38 GMT 1
Have a led tail light bulb in the standard holder which works OK, so can't see why the indicators wouldn't be the same.
Post by unrealedd on May 25, 2016 6:25:48 GMT 1
If you fit led bulbs in the indicators there's a high chance you will either have to replace the relay or fit resistors to the indi's to get the correct flash rate I believe for MOT its 60 - 120 times a minuite.
Post by beardy on May 25, 2016 8:34:01 GMT 1
as said above. they dont draw enough wattage to operate the flasher relay if at all.
Post by headcoats on May 26, 2016 12:32:44 GMT 1
Does anyone know what relay I need to get then and is it the 3 way plug type ? Cheers
Post by unrealedd on May 26, 2016 13:23:29 GMT 1
You need to get correct wattage relay for the indicators, you can use a 2 pin I will have to check the wires colours but it's quite simple. Why do you want LEDs anyway?
Post by headcoats on May 26, 2016 19:18:42 GMT 1
Maybe the aftermarket ones I have don't seem that bright
Mine are black inside and have seen some which have silver paint in to help reflect the light
Shall I just buy some silver spray !
Post by midlifecrisisrd on May 28, 2016 16:08:52 GMT 1
Shall I just buy some silver spray ! Yes I've sprayed them silver inside before Made a big difference Steve
Post by jon on May 29, 2016 8:33:20 GMT 1
Headcoats, I bought some chrome spray from Wilko to do my pattern indicators.
Worked surprisingly well.
Post by bofski25 on May 30, 2016 10:01:55 GMT 1
Before spraying the insides try putting baking tin foil inside to see if they look any brighter should give you a good idea of what they will look like if you spray them
Bofski
