Post by 4ce on Apr 24, 2016 16:45:29 GMT 1
Hi all Am I right in thinking I can fit the centre stand with the Gibson Allspeed copy pipes?
Post by howard on Apr 24, 2016 20:42:48 GMT 1
No you can't fit a main stand with the Gibsons , you also need the tidy up the side stand too .
Post by Norbo on Apr 25, 2016 10:57:52 GMT 1
Thats why so many dont have them fitted to day as every one put after market pipes on and just put the main stand aside . sold the bike . then years later threw the stand as they had no use for it any more .
Post by wozzap on Apr 25, 2016 12:13:55 GMT 1
No you can't fit a main stand with the Gibsons , you also need the tidy up the side stand too . I spaced both the pipes inwards about 6mm on the rear mounts and pulled the side stand spring towards the stand with a cable tie to stop it touching the left hand pipe.
Post by 4ce on Apr 25, 2016 20:42:53 GMT 1
Thanks all for your advice, No you can't fit a main stand with the Gibsons , you also need the tidy up the side stand too . I spaced both the pipes inwards about 6mm on the rear mounts and pulled the side stand spring towards the stand with a cable tie to stop it touching the left hand pipe. I will look into this, thanks
dal68
Post by dal68 on Apr 26, 2016 17:41:57 GMT 1
My mate has gibsons on his 400c with center stand not sure if there same as 400f
