Post by arrow on Apr 15, 2016 10:37:56 GMT 1
After many years of thinking about it we finally got round to having the drive done. Looks like something on the western front at the moment! They rolled up today 8 o'clock sharp and started using one of those 2 stroke stone cutting things. Well this thing was revving up and down for 25 minutes non stop. I couldn't stand it anymore and had to say something. So I opened the window and shouted down; I said, excuse me, but you know that thing is a little bit lean at the bottom!
Post by Yogi on Apr 15, 2016 10:40:13 GMT 1
lol,I'm surprised your not trying to fit a pump to it
Post by Norbo on Apr 15, 2016 11:34:54 GMT 1
LOL
Post by steve h on Apr 15, 2016 12:36:41 GMT 1
Post by risolc on Apr 15, 2016 16:37:57 GMT 1
+1 LOL
Post by mellow on Apr 15, 2016 18:42:59 GMT 1
should have gone and adjusted the high/low & tickover screws on it
Post by steeley on Apr 15, 2016 18:57:59 GMT 1
nice .
Post by farmboy on Apr 15, 2016 19:19:14 GMT 1
Its amazing how those little engines stand all the abuse they get , sure they are pulling 10,000 + rpm max out
Post by arrow on Apr 15, 2016 20:49:28 GMT 1
Its amazing how those little engines stand all the abuse they get , sure they are pulling 10,000 + rpm max out I just hope the air filtration side of things has been well designed. They only ever operate in air loaded with tiny abrasive particles, not good.
Post by reggieperrin on Apr 15, 2016 21:27:07 GMT 1
Amazingly, the smaller Stihl engines run a bizarre big end bearing where the rollers are individual.... You slide the con-rod over to one side of the crank, load all the rollers in with a bit of grease, and then slide the con-rod carefully back over the lot....!! When the cases are back together, the rod can't move and the rollers all stay in place as if by magic.....
I thought I had a roller missing but the dealer said, No, they all have a bit of slop in them....
It rev's it's tits off permanently and is always sound...
Post by steven on Apr 16, 2016 9:30:39 GMT 1
...same as a Villiers bottom end with the loose big end rollers. This guy strips a Villiers bottom end in about 3 minutes. steven.
Post by arrow on Apr 16, 2016 10:20:41 GMT 1
Aw, he was a bit clanky with them spanners! Nice use of the hammer too.
