Post by russpuss on Apr 11, 2016 22:06:52 GMT 1
Thoughts on these guys, fresh rebuild after holing a piston on a newly built engine.
Post by muttsnuts on Apr 12, 2016 13:31:59 GMT 1
look abit grey, possibly too much oil, you running premix or pump ?
Post by russpuss on Apr 12, 2016 13:44:39 GMT 1
Oil pump with genuine cable and set up to spec
Post by russpuss on Apr 12, 2016 13:46:13 GMT 1
Must admit, only did about 15 miles and no more than 4K revs and when I put the engine back together I lubed everything internally with 2t.
Post by muttsnuts on Apr 13, 2016 11:14:41 GMT 1
run it for more miles and also will need a few more revs really to make sure its clear etc before doing the plug chop and you do need to do the chop properly otherwise the colour won't really tell you anything
