Post by hardhatharry on Apr 7, 2016 22:01:58 GMT 1
The plastic main and reserve pipes with the filter on fall out of the fuel switch, what adhesive should I use to glue it into the switch?
Post by unrealedd on Apr 7, 2016 22:16:01 GMT 1
JB WELD should do the trick fuel resistant once fully cured and hardened. Hope this helps unless someone can surges sommint else.
Post by spooch63 on May 29, 2016 12:12:19 GMT 1
JB WELD should do the trick fuel resistant once fully cured and hardened. Hope this helps unless someone can surges sommint else. +1 works quite well
