Post by hardhatharry on Mar 29, 2016 16:15:31 GMT 1
Hi
Does a 1976 C Clutch fit a 1977 D engine?
Post by muttsnuts on Mar 29, 2016 16:20:03 GMT 1
so long as you keep the 2 primary gears matched then it should all be fine
Post by hardhatharry on Mar 29, 2016 17:50:32 GMT 1
Does that mean I could fit a 68 tooth 250 clutch with a 250 primary gear?
Post by muttsnuts on Mar 30, 2016 15:23:43 GMT 1
never done it myself but yes that should work
have you checked on the Air Cooled forum as I am sure somebody will have done that for sure
Post by hardhatharry on Mar 31, 2016 13:21:25 GMT 1
Yes but no real answers
Post by muttsnuts on Mar 31, 2016 18:09:01 GMT 1
ah ok, they can be like that, leave it with me I'll find out for you
Post by muttsnuts on Mar 31, 2016 18:35:59 GMT 1
I am being told you should be ok to fit the 250 clutch so long as the primaries are swapped as a set and from same model e.g D to D and E to E
Post by arrow on Mar 31, 2016 20:30:30 GMT 1
Does that mean I could fit a 68 tooth 250 clutch with a 250 primary gear? If the swap works don't forget you will need to run the 22T gear on the worm shaft and not the 21T. This would reduce the oil to the motor. As 400c/d oiled less anyway than 400e/f, be careful.
Post by hardhatharry on Mar 31, 2016 20:41:28 GMT 1
oooo er might as well get a 400 clutch then, I have 3 but all 250 ones
Post by arrow on Mar 31, 2016 20:45:28 GMT 1
There is an issue with the tacho drive gear also..... Have you asked any breakers for help finding the correct parts?
Post by hardhatharry on Mar 31, 2016 22:57:11 GMT 1
I have a 400 tacho drive
Post by muttsnuts on Apr 1, 2016 17:31:39 GMT 1
Does that mean I could fit a 68 tooth 250 clutch with a 250 primary gear? If the swap works don't forget you will need to run the 22T gear on the worm shaft and not the 21T. This would reduce the oil to the motor. As 400c/d oiled less anyway than 400e/f, be careful. Ah, good catch that Gary, not really thought about the oil pump, but your right, they are 1 tooth different
Post by hardhatharry on Apr 3, 2016 20:16:51 GMT 1
Well I managed to bag the RD400 clutch that was on eBay so I hope it all fits together
