Post by Bozzy on Mar 24, 2016 18:51:15 GMT 1
Painted a set of wheels with a polished edge and having major issues getting a clean line between polished face rim and flat painted section. (the spokes are perfect not issues).
I am getting paint chipping back etc meaning re-masking and painting. Just wondered if any tricks that's been found ie. blade around the edge or should I have painted part of the edge then use a blade to cut back etc.....touchup edge with paint after.
I expect the edge will be crap after polishing the rim after normal use in any case but would appreciate any feedback so as not to waste any more time and paint!
Perhaps I am trying to get perfection when its not possible.
Post by sandpiper on Mar 24, 2016 20:02:58 GMT 1
ive just painted a set of wheels and used 4mm pinstriping tape as it goes round corners easily, i polished the rim first.hope this helps.
Post by wonkywheel on Mar 24, 2016 20:04:44 GMT 1
Post by davey on Mar 24, 2016 20:14:34 GMT 1
I masked the edges with a non bleed tape the trimed it with a sigle egded razor blade so just the pollished egde was masked . After painting pull the tape when the paint has tacked off try not to leave it till its dry and use a good quality polyurathane 2 part paint if you can , yacht paint is excellent .
Post by farmboy on Mar 24, 2016 20:31:19 GMT 1
I used regular black insulation tape , it forms into the concave shape of the rim, and leaves a cleaner edge than masking tape. Just as also said use some pinstripe tape to make a tight edge , than use any masking tape to cover the main parts.
Post by Delbert on Mar 24, 2016 23:05:54 GMT 1
Much the same as above , polished first then masked I then scotch brited up to the edge of tape
Post by Bozzy on Mar 24, 2016 23:40:46 GMT 1
Thank for above I think the error I made was priming and painting Upton the edge now got some edge damage. Looks like masking and redo rim section going to get some fine tape as suggested cheers
stevep
Post by stevep on Mar 24, 2016 23:58:21 GMT 1
good advice above ref lining tape also make sure all polish residues are cleaned off
Post by arrow on Mar 25, 2016 0:00:35 GMT 1
I brush painted mine. No masking tape but painted right on to the polished rim but featherd it off with the brush. Cut the edge back later with 600 wet/dry and re-polished.
Post by bare on Mar 25, 2016 3:07:25 GMT 1
Sighh. Use a wee paintbrush and simply paint the silly wheels. NO masking. Use a solvent wetted rag and wipe off any/all misses. Dead Simple. Masking to spray the paint on is a Foolish waste of time.. better spent Imbibing :-) Ohhhh brush method 'at least' equals the OEM Paint job. Try it?
Post by Deleted on Mar 25, 2016 4:36:05 GMT 1
+1 Bare, that's what I did with mine
Post by steeley on Mar 25, 2016 7:58:59 GMT 1
Ah bare ,what you are saying is 2 and a bit hours relaxing masking time on each wheel is time wasted /down the drain .
Post by JonW on Mar 25, 2016 12:36:45 GMT 1
Plenty of ways to skin a wheel of course... use what you feel most comfortable with, for me its cans... misspent yoof perhaps LOL!
Post by oldelsieboy on Mar 25, 2016 12:43:26 GMT 1
what you are saying is 2 and a bit hours relaxing masking time on each wheel is time wasted /down the drain . Bloody hell, don't know what your doing but I've stripped, masked & painted a pair in less time OEB
Post by steven on Mar 25, 2016 18:11:54 GMT 1
Sighh. Use a wee paintbrush and simply paint the silly wheels. NO masking. Use a solvent wetted rag and wipe off any/all misses. Dead Simple. Masking to spray the paint on is a Foolish waste of time.. better spent Imbibing :-) Ohhhh brush method 'at least' equals the OEM Paint job. Try it? LOL @ ..."better spent Imbibing."........ I concur ! steven. ps, I just got my wheels powder coated all black.....much less hastle ! but no good if your going for the origonal look i dont suppose.
Post by headcoats on Mar 25, 2016 19:22:12 GMT 1
I brush painted mine. No masking tape but painted right on to the polished rim but featherd it off with the brush. Cut the edge back later with 600 wet/dry and re-polished. Bit different but I sprayed my KR1S wheels and masked with normal masking tape then wet and dried the rough edge back to good
Post by Fingermaus on Mar 25, 2016 20:48:31 GMT 1
I had mine blasted at my local powder coaters (LSN), polished the shiny/brushed bits first,sprayed the lot with BBQ paint,and carefully wiped the paint off the shiny/Brushed bits with some panel wipe saturated cloths in-between each coat. Sod masking. I used to do that and I realised my life was slowly ebbing away.......masking. Chuffed with the results.It was loads quicker and infinitely less boring that masking.
Post by JonW on Mar 25, 2016 23:52:49 GMT 1
Im the other way, I decided masking was the way forward after I spent too much time wiping away overspray
Post by kostas on Mar 26, 2016 8:29:34 GMT 1
There should be no rush during a proper rebuild.. Polish Clean residue and mask Prime and paint All within a weeks work!! Kostas
