Post by headcoats on Mar 23, 2016 13:49:40 GMT 1
Any welders out there got an opinion on if this broken fin is repairable and will it warp the barrels if it was welded/repaired ?
Post by arrow on Mar 23, 2016 13:58:24 GMT 1
Post by oldelsieboy on Mar 23, 2016 14:19:37 GMT 1
+1 Tony does some excellent ali weld repairs. OEB
Post by Deleted on Mar 23, 2016 15:20:36 GMT 1
IMO if he Tigs it not too much heat should get in, a series of tacks probably then fill in the gaps
Particularly if he can hold the broken bit in situ and use it as the heat sink, all be it small
ie roll the bead from the broken bit onto the barrel
Post by oldelsieboy on Mar 23, 2016 15:27:49 GMT 1
Post by headcoats on Mar 23, 2016 15:30:37 GMT 1
Wow that is a good repair
Post by oldelsieboy on Mar 23, 2016 15:42:52 GMT 1
This was the repair he made to my chain damaged crankcases. OEB
Post by arrow on Mar 23, 2016 15:50:24 GMT 1
Wow that is a good repair Yeh, he's good mate. Sound bloke too.
Post by russpuss on Mar 23, 2016 16:16:40 GMT 1
They call him Shag I believe? He did my carbs (ultrasonic clean and yellow passivate), top workmanship.
Post by dusty350 on Mar 23, 2016 19:26:35 GMT 1
Hi I had an Rd400 barrel with a large piece of fin broken off. I dremmeled a matching piece of fin from an old knacked barrel ( I did't have the original part), and took it to my local engineers who welded it on perfectly. You would never know it had been repaired and the barrels had a vapour blasted finish too. So a good welder should be able to do it for you if you don't want to post it off. Dusty
