Post by muddyfox on Mar 16, 2016 16:02:32 GMT 1
hello chaps im after a throttle cable to fit my ypvs project, the throttle cable on this bike snapped, ive bought a cable for a N model which is what this bike is, however the 2 ends that lead to the carbs are way to short, the lenth on the cable that snapped is 45cm and the N model on is just 2 short as the noodle on the TM's are inline with frame crossmember hence the long lenth sleeves
im desparate for some info!!!!
Post by bazzer5115 on Mar 16, 2016 18:46:03 GMT 1
I make all my own cables-clutch,throttle,power valve,etc.All my parts-inner,outer cables,nipples,ferrules,splitters if you need them etc I get from "venhill engineering" they are so helpful and knowledgable.If you can solder you can make all your own custom cables that fit and work perfectly. They also do brake lines to your own dimension/requirements Baz
Post by muttsnuts on Mar 16, 2016 20:34:11 GMT 1
yep +1 for Venhill
Post by muddyfox on Mar 17, 2016 11:17:20 GMT 1
thanks for the replies!, i figured out how to split the juntion box, bought a cw50 cable as the 2 parts to the carbs are 45cm long, so ill add them to the rd cable, job done!!
