Post by stusco on Mar 11, 2016 9:33:07 GMT 1
Does 4l0 throttle cable fit 31k carbs got a pattern one but can't remember what I bought it's not got enough adjustment too much slack on the throttle
Post by midlifecrisisrd on Mar 11, 2016 11:06:10 GMT 1
Yes it fits
Pattern cable is most likely the problem
Got to be either genuine or one from norbo (made in the same place as genuine)
Post by stusco on Mar 11, 2016 16:11:49 GMT 1
Mine is from Norbo fully adjusted both ends got about a third slack ,it's a f2 tube n throttle don't know if I'm in the wrong hole as I think there are two Nope just checked I'm in the right hole
Post by dave1963 on Mar 11, 2016 19:56:47 GMT 1
Got genuine on mine with 31k carbs no problems
Post by jon on Mar 12, 2016 9:56:07 GMT 1
Stusco,I'm sure your wife is also pleased you are in the right hole Jon
Post by midlifecrisisrd on Mar 12, 2016 11:22:12 GMT 1
Stusco,I'm sure your wife is also pleased you are in the right hole Jon Always best to remember the "2nd down from the back of the neck" rule Steve
Post by midlifecrisisrd on Mar 12, 2016 11:24:09 GMT 1
Mine is from Norbo fully adjusted both ends got about a third slack ,it's a f2 tube n throttle don't know if I'm in the wrong hole as I think there are two Nope just checked I'm in the right hole What switch gear are you using? F2 and 31k tubes are different. They do fit but not sure if it alters the length Steve
Post by stusco on Mar 12, 2016 13:42:15 GMT 1
Ive got f2 switchgear and tube
Post by stusco on Mar 20, 2016 20:31:15 GMT 1
Solved my problem today the f2 tube has two holes so I cut a slot between them and fitted the cable in the other hole removing the cable slack
