Post by muttsnuts on Mar 6, 2016 10:54:24 GMT 1
Anybody know if there are any differences between a 3540R and F2 frame, they look the same, but thought I'd ask/check............
Post by jon on Mar 6, 2016 11:17:31 GMT 1
Dave, there are a few. Some more major than others.
The important one is the headstock. The bearing cups are different sizes and Jap YPVS is not interchangeable with it. However more modern Yamaha also uses this size so fork changes are easier. My 4HW forks (baby 3XV) fit straight in.
There are also a few extra lugs for the faring, 4 in total but easily removed.
Otherwise they are identical.
Post by Bazille on Mar 6, 2016 11:19:19 GMT 1
Am i right in thinking that they have different headrace bearings, one being 55mm diameter and top one being 47mm?
Post by midlifecrisisrd on Mar 6, 2016 11:47:25 GMT 1
Yes headstock uses tapers as standard so bigger
Uses standard rgv sizes so easy for a hybrid.
Biggest pain of the extra brackets is the 2 welded to the top frame rails. You can't make it a naked without cutting them off.
Also no lugs for frame infills at headstock
No top lug for N rad guard. Just the F ones
Post by muttsnuts on Mar 6, 2016 12:57:25 GMT 1
cheers guys, you live and learn that's for sure !
somebody was wanting the 350R frame and cases so they could make their F2 a matching numbers bike, so thought I'd make sure of my facts before saying it should all swap over, glad I checked now !
Post by kosaprasa on Mar 6, 2016 14:40:25 GMT 1
and petrol tank is diffrent - lugs for side frame covers
Post by Deleted on Mar 7, 2016 11:27:45 GMT 1
Just got a 350R frame plus a heap of parts for less than 100 quid in your language, could someone possibly explain in pictures please, not sure if I can rebuild it back to original as plastics are hard to come by down here
was thinking of doing a 350N with clip ons but don't know now, I didn't really want to butcher the frame at all
I guess I'll look in the rebuilds section to see if any have been done
Suggestions please?
Post by jon on Mar 7, 2016 12:05:27 GMT 1
Steve, I'm sure my R frame had the lugs for the infills as I remember chopping them off.
Post by midlifecrisisrd on Mar 7, 2016 14:14:54 GMT 1
Steve, I'm sure my R frame had the lugs for the infills as I remember chopping them off. Jon Mine had the front tabs but not the mushrooms for the 4 rubbers. Had to make them and weld them in on the naked vj21 hybrid I did Mine was a 92 k plate Steve
