Post by looey on Mar 3, 2016 18:41:19 GMT 1
How many people have fitted a 7mm wide Gearchange shaft seal with greater success over the standard 5mm wide seal ?.
I have 2 double lipped seals here, one of each thickness.
Is it a worth while upgrade over the standard 5mm seal ?.
Post by muttsnuts on Mar 3, 2016 20:33:44 GMT 1
it won't hurt and if anything should move the sealing lip onto a different part of the gear change shaft, so it shouldn't be worn and therefore should seal better as well
Post by looey on Mar 3, 2016 20:57:01 GMT 1
Cool ta, The outer casing has been bushed, so there's not a lot a movement in the shaft. Think the current seal is just old and knackered
Post by muttsnuts on Mar 3, 2016 21:52:25 GMT 1
..... is just old and knackered sounds like your describing me !
Post by looey on Mar 3, 2016 22:05:43 GMT 1
Post by rigga on Mar 3, 2016 22:11:08 GMT 1
Speak for yourself .....
No you're right
Post by JonW on Mar 3, 2016 22:21:44 GMT 1
Shafts are cheap enough that you should replace them when worn, its the same unit in the 4L0 as the banshee, via the ypvs...
Post by jackjabba on Mar 4, 2016 17:03:45 GMT 1
Your only as old as you feel, until you walk past a mirror.
Post by mcguyver on Mar 5, 2016 11:55:50 GMT 1
I fitted one just today, along with the case bush. No issues at all.
Post by copper99 on Mar 5, 2016 12:53:43 GMT 1
I fitted a twin lipped 7mm one and it worked a treat for me.
Post by looey on Mar 5, 2016 13:36:14 GMT 1
Cool, Gonna attempt it in a bit, what's the easiest way to get the old seal out without a seal hook ?. Scrap that, it's out, a bit of heat applied, then careful persuasion with a srcewdriver from the inner part of the seal
Post by rigga on Mar 5, 2016 14:34:48 GMT 1
Where can the 7mm seals be sourced from ?
Post by looey on Mar 5, 2016 15:02:42 GMT 1
Got mine from Simply Bearings.
Cost me £4.54 including postage for 1x standard 5mm and 1x 7mm,
Be careful when ordering, as there are lots of similar types with single lips etc.
You want a 12 x 22 x 7mm rotary shaft oil seal with garter spring - R23 double lipped
Post by copper99 on Mar 6, 2016 21:26:18 GMT 1
