Post by looey on Mar 1, 2016 12:03:47 GMT 1
Just refurbed a genuine 350LC Tap but the on/reserve pipe/gauze plastic part that pushes into the top of the tap and resides in the tank isn't very tight.
I reckon just the petrol sloshing about in the tank will probably knock it out sooner or later.
Anyone glued this back in successfully before or anyone know what to use to stick this back in ?.
Post by marsbar350 on Mar 1, 2016 16:06:02 GMT 1
try roughing the edges of the filter with a file and see if its tight enough jb weld could do the job but that's kind of a permanent fix or stop being a tight b*****d and buy a new tap
Post by looey on Mar 1, 2016 16:20:36 GMT 1
Done it now, fixed it in with the tiniest slither of slow cure original Araldite, which claims to be petrol resistant. I ain't paying £65 for a new tap just cos the internal filter isn't a tight fit
Post by headcoats on Mar 1, 2016 16:54:53 GMT 1
Good point and other fuel tap parts should be available separately too
Post by oldelsieboy on Mar 1, 2016 17:01:27 GMT 1
Post by looey on Mar 1, 2016 17:49:12 GMT 1
Yeah I always check the parts lists before I buy anything. Quite often cheaper than buying pattern tat
