Post by seanclarky on Feb 7, 2016 20:45:00 GMT 1
Just stripped the carb on my latest project (ts185) and it's in quite a mess! There's lots of red/browm gooey deposits in the carb and The needle valve is stuck solid, what's the best way to get it out and is paraffin the best bet to clean up the mess? Cheers
Post by 4l04ever on Feb 7, 2016 21:47:57 GMT 1
Give it a few cycles in an ultrasonic cleaner.....
Post by seanclarky on Feb 8, 2016 16:14:43 GMT 1
Give it a few cycles in an ultrasonic cleaner..... cheers, I haven't got one though, are they worthwhile getting for the odd carb now and again? Or is the best bet to get a small local firm to clean it up?
cheers
Post by russpuss on Feb 8, 2016 16:23:55 GMT 1
cheers
I borrow this off a friend and works a treat
Post by seanclarky on Feb 9, 2016 10:32:34 GMT 1
cheers Russ, I need a friend like that!
Post by muttsnuts on Feb 9, 2016 20:18:58 GMT 1
I do a full carb service for £40 a pair of carbs, plus postage back, so a single carb would be £20 plus postage back if your interested, done lots of carbs for people on here, so ask about if you want to gauge my service
The carbs are fully stripped, ultrasonically cleaned (in proper carb cleaner) and all circuits and jetting checked, the carb is then rebuilt and set back to factory settings, assuming you have the correct jets, if not then you can either get the correct jets, or get it back set up as best I can with what is there
PM me if interested
Post by seanclarky on Feb 10, 2016 13:07:18 GMT 1
nice one dave, pm on its way
Post by muttsnuts on Feb 13, 2016 21:33:49 GMT 1
your carb is no longer a problem, fully stripped, all the crap removed and just having a fiknal hot bath before a final clean and reassmeble.........I'll post some picks up of the before and after of the emulsion tube later !
Post by seanclarky on Feb 15, 2016 19:57:49 GMT 1
Brilliant job Dave cheers !
Post by muttsnuts on Feb 15, 2016 20:13:06 GMT 1
heres some pictures emulsion tube just after I got it out and after I'd cleaned it and the carb during rebuild and now posted and on its way back to you
Post by seanclarky on Feb 15, 2016 20:45:11 GMT 1
It was a real mess Dave, thanks again for sorting it so quickly, brilliant service!
