Post by Bozzy on Jan 20, 2016 12:11:36 GMT 1
guys hoping someone can guide me here. on my 31k it go what I think a n1 or f1 swing am. not sure how to check but it's def not the original 31 k as its a box section with the slide in break mount.
what I wanted to know have chance to get a f2 arm but seller says it's different to the old type? no idea what he means. does any of the f1 f2 fit into the 31k backend?
thanks
Post by midlifecrisisrd on Jan 20, 2016 12:20:23 GMT 1
All ypvs swing arms fit in all ypvs bikes.
The lc2 31k arm is box section but where the back wheel mounts is just flanges.
The F1/2/R are box section all the way to the end.
This means the later ones used a longer wheel spindle and different adjusters.
Consequently the F1/N1 had indents in the exhausts to clear the spindle so you can't fit the later arm to an lc2 with the standard lc2 pipes
Hope that helps, Steve
Post by Bozzy on Jan 28, 2016 15:15:49 GMT 1
thanks that really helps. I was looking at a f2 arm getting it chromed but its a shock how much the bearings cost think I will be looking at 100 quid+. it's either this or a metachex
Post by midlifecrisisrd on Jan 28, 2016 15:25:38 GMT 1
thanks that really helps. I was looking at a f2 arm getting it chromed but its a shock how much the bearings cost think I will be looking at 100 quid+. it's either this or a metachex Yambits do the pivot needle rollers for £30 a pair on ebay May be worth speaking to norbo as he probably does them as well. I know he does the seals and bushes for the dogleg a lot cheaper than Yamaha Steve
Post by kosaprasa on Jan 28, 2016 23:35:20 GMT 1
for 30 quid posted i sell swing arm for F2/Fi...
Post by Bozzy on Feb 4, 2016 11:08:55 GMT 1
before I start to go down thie route of another swing arm I have been trying to locate the plastic chain guard that fixes to the top of the arm. see some are rubber but they appear not to be available. anyone got a pointer to were any are available ?
Post by jumpstart on Feb 4, 2016 11:35:59 GMT 1
maybe in the wanted section bossy, worth a try ?
Post by jumpstart on Feb 4, 2016 11:36:53 GMT 1
maybe fowlers in bristol?
Post by JonW on Feb 4, 2016 12:46:01 GMT 1
you can make one from a kitchen chopping board, Ikea used to do one the right thickness... Someone did remake these a while back as well ISTR...
Post by JonW on Feb 4, 2016 12:47:28 GMT 1
May be worth speaking to norbo as he probably does them as well. I know he does the seals and bushes for the dogleg a lot cheaper than Yamaha Steve This is really key when doing these ypvs monoshock suspensions, the parts will bankrupt you if you dont shop around, and norbo has had some parts remade that are now nla too.
