Post by kostas on Jan 7, 2016 22:28:55 GMT 1
Hi Some questions on Flatslide Mikunis. Im trying to identify what I have.. No markings or numbers stamped on. They came off an 1991 RGV VJ22. I checked the bore diameter at the side they mount on the engine and it measures 32mm. Does this means I have 32mm carbs. (Maybe this is the most stupid question I have asked so far). Second question: The plastic nipple at the bottom of the float bowl is broken How do I replace this? Can I find a spare one? Motocarb maybe? Thanks!!
Post by markhoopy on Jan 8, 2016 0:29:37 GMT 1
Yes to your 32mm question I can't help with identifying the carbs but Allens Performance might have what you need. Does the crack in the float bowl leak at all? www.allensperformance.co.uk/
Post by Eyrey1 on Jan 8, 2016 4:24:12 GMT 1
carbs are tm32ss they are off jap model restricted bike uk bike runs tm34ss still bloody good carbs though and i dont think there is much if any difference in performance exactly the same carb and body just 2mm smaller on the outlet side people bore them out the 2mm sean at ttw on rgv forum sells new carb bowls as that bottom nipple always gets broken off usually by breaking a chain complete bowl is 33 quid here www.thetuningworks.co.uk/store/product_info.php?cPath=21_124&products_id=1074
Post by steeley on Jan 8, 2016 6:29:13 GMT 1
hi Kostas, as Eyrey said they are jap model carbs put the jet sizes up or better still have a look on the Rgv250 forum I think there is a section about carbs/ jap models. that nipple has a rubber pipe going to a point on the carb /power jet.
Post by kostas on Jan 8, 2016 6:34:11 GMT 1
Thanks Eyrey.
Massive chain damage is what I have!
Cheers
