Post by russpuss on Nov 25, 2015 1:24:50 GMT 1
How stiff should the lever be? I've stuck new springs in and the cable is free when the side casing is off but it's bloody stiff when all connected up? It has no more plates in the basket, are they just stiff?
Post by Delbert on Nov 25, 2015 8:05:12 GMT 1
If you have used heavy duty springs it will be , some including myself used three std and three hd . Still quite heavy though
Post by LC_BOTT on Nov 25, 2015 9:36:48 GMT 1
Had the same problem with mine, (completely standard 250) then bought a genuine Yam cable and it's totally different, totally transformed the clutch action.
Post by oldelsieboy on Nov 25, 2015 9:45:31 GMT 1
Had the same problem with mine, then bought a genuine Yam cable and it's totally different, totally transformed the clutch action. Ditto OEB
Post by russpuss on Nov 25, 2015 10:03:19 GMT 1
The springs are new standard off Norbo, the cable is what was on the bike from Germany, think I'll just swap that to eliminate it anyway, thanks.
Post by dave1963 on Nov 25, 2015 13:16:17 GMT 1
I have 3 hd 3 normal fitted a new genuine cable and it's much better a little bit heavy but ok
