Post by russpuss on Oct 21, 2015 18:04:44 GMT 1
Am I right in thinking that everything is there except the unit? Can I just plug 1 in and away I go?
Post by midlifecrisisrd on Oct 21, 2015 19:55:42 GMT 1
Have done it to a 31k and that's all it was
Post by markhoopy on Oct 21, 2015 22:42:32 GMT 1
Post by russpuss on Oct 21, 2015 23:07:42 GMT 1
Can't see me doing funds for her as blacklisted by lots of people!
Post by onewheelsenough on Oct 22, 2015 0:00:21 GMT 1
got one here if you still need one £8 posted. cheers gaz
Post by russpuss on Oct 22, 2015 4:14:15 GMT 1
got one here if you still need one £8 posted. cheers gaz I'll try that please, send me a PayPal addy?
Post by 4l04ever on Oct 22, 2015 20:04:51 GMT 1
You have to change one wire over by the flasher relay too.
Post by russpuss on Oct 22, 2015 20:32:09 GMT 1
You have to change one wire over by the flasher relay too. Any idea which 1?
Post by 4l04ever on Oct 22, 2015 21:00:14 GMT 1
Connect the yellow/green wire in place of the black wire. Both wires will be next to the flasher relay to the left of the battery.
This is assuming it is for a 4L0/4L1.
Post by russpuss on Oct 27, 2015 17:34:40 GMT 1
Stuck the unit in and swapped wires over, nothing, works with black wire fine, any more thoughts?
daw
Post by daw on Oct 30, 2016 16:24:29 GMT 1
Did you ever solve the issue? I just bought a unit for my import, fitted it and swapped the relay wires and indicators did not work at all
Post by rigga on Oct 30, 2016 17:21:09 GMT 1
Probably the reed switch in the clocks that is used in conjunction with the cancelling unit.
That's if the indicators still dont self cancel, if they don't work at all forget that.
daw
Post by daw on Oct 30, 2016 19:15:42 GMT 1
With the relay wires switched round the indicators don't work at all. Changed back to the black wire and they do. Wondering if it's the self cancelling unit I bought that's faulty.
Post by russpuss on Oct 30, 2016 20:08:16 GMT 1
With the relay wires switched round the indicators don't work at all. Changed back to the black wire and they do. Wondering if it's the self cancelling unit I bought that's faulty. Mine still the same, is there a way to test the switch in the speedo?
Post by mattybeckett on Jan 1, 2017 15:59:18 GMT 1
I've had same problem ' the indicators work without swapping wire but don't cancel. Swap wire and nothing at all.
Post by gci_scot on Jan 2, 2017 17:06:37 GMT 1
I have the same issue as well. Added the cancelling unit and swapped the wires. Indicators do nothing. Work fine when swapping the wire back to black. Anyone know of any way to test this problem?
Post by russpuss on Mar 26, 2017 18:04:15 GMT 1
Bump
