Post by russpuss on Oct 28, 2015 9:02:37 GMT 1
Right chaps, dropped the oil and it's a lovely creamy reddy brown, thoughts on what to replace or should I be whipping the heads off now? Ignore any other foreign bodies in there, it was only the fluid that came out.
Post by russpuss on Oct 28, 2015 21:20:51 GMT 1
Looking like condensation, stripped clutch and cleaned all up, back together, fresh oil and water, put the second hand stator on and it's missing again. Tomorrow night borrow the one that worked again to see if that solves it as it ran perfect before. Hopefully it will so that can run up to temp and flush everything out.
Post by russpuss on Oct 28, 2015 21:23:41 GMT 1
Stripped front callipers as they were binding, started stripping paint ready for a refresh whilst they're in bits, new seals required.
Post by russpuss on Oct 28, 2015 21:26:18 GMT 1
Left hand silencer has been cut at the front and welded back up but it's twisted and doesn't sit right on the bike, luckily it's been cut on the original welds so hoping it can be recut and welded properly, question is guys, why would it have been cut? Is there a restricter in there? Why only the left one?
Post by russpuss on Oct 28, 2015 21:29:49 GMT 1
Self cancelling fitted, swapped yellow for black wire and no indicators, is there something else to swap? Battery strap came so fitted that.
Post by marsbar350 on Oct 28, 2015 21:37:01 GMT 1
german bikes had restricters fitted there
Post by russpuss on Oct 28, 2015 21:39:25 GMT 1
german bikes had restricters fitted there Just the left?
Post by oldelsieboy on Oct 28, 2015 21:41:08 GMT 1
german bikes had restricters fitted there Only German 4L2 model 250cc bikes had restricted exhausts. OEB
Post by russpuss on Oct 28, 2015 21:51:49 GMT 1
Where do I find numbers on the exhausts to check what they are please? If they are 250 and the restricter in the left has gone, is there 1 in the right to remove too and will they work the same as 350 when done?
Post by marsbar350 on Oct 28, 2015 21:52:27 GMT 1
german bikes had restricters fitted there Only German 4L2 model 250cc bikes had restricted exhausts. OEB as its a german 250 russpuss is restoring.i left that bit out of the answer russ maybe it hasn't been removed yet check the embossed number by the hangar bracket
Post by russpuss on Oct 28, 2015 22:07:53 GMT 1
Only German 4L2 model 250cc bikes had restricted exhausts. OEB as its a german 250 russpuss is restoring.i left that bit out of the answer russ maybe it hasn't been removed yet check the embossed number by the hangar bracket It's a 350, will nip in garage now to check numbers.
Post by russpuss on Oct 28, 2015 22:14:51 GMT 1
Post by russpuss on Oct 28, 2015 22:15:35 GMT 1
Back cut
Post by marsbar350 on Oct 28, 2015 22:15:48 GMT 1
Post by russpuss on Oct 28, 2015 22:15:55 GMT 1
Front cut
Post by marsbar350 on Oct 28, 2015 22:19:08 GMT 1
restrictor fitted where downpipe meets first cone
Post by LC_BOTT on Oct 28, 2015 22:25:29 GMT 1
Exhaust has probably been cut open to retreive a broken baffle, had to do several in the past. Maybe the reason why one has only been done?
I'd also be changing the water pump seal, that looks like a lot of condensation, unless it's really cleaned up?
Post by russpuss on Oct 28, 2015 22:25:33 GMT 1
restrictor fitted where downpipe meets first cone Well that is in a different place to this then, and this is a genuine 4lo so I'll see if I can get it sorted by a friend at race fit uk.
Post by russpuss on Oct 29, 2015 17:47:09 GMT 1
Wheels back, and couldn't be happier, look the dogs danglies, not much polishing needed either and all casting marks intact.
Post by marsbar350 on Oct 29, 2015 17:56:29 GMT 1
they do look real nice russ thay 80s paint did come in useful get that boot hoovered out
Post by russpuss on Oct 29, 2015 19:26:58 GMT 1
Looking like condensation, stripped clutch and cleaned all up, back together, fresh oil and water, put the second hand stator on and it's missing again. Tomorrow night borrow the one that worked again to see if that solves it as it ran perfect before. Hopefully it will so that can run up to temp and flush everything out. Nowt wrong with stator, schoolboy error, dodgy plug!
Post by russpuss on Oct 29, 2015 21:48:51 GMT 1
Busy night, stripped all bearings from wheels and hubs, that was easy..... Ran bike for half an hour, Rev counter all good and temp gauge, runs like a Swiss clock. Emptied all fluids again and refilled with new. Starting to write a little list of needs, clutch springs don't look standard and you need a strong hand to work lever, all other parts good so think some different springs in will sort that. Wheel bearings, throttle cable, retaining tabs for wheels, carb to barrel rubbers as these cracked. Knackered 2 spacers in wheels getting bearings out (Or Bri did!) sorry Bri, will order those too. Front brake seals and paint for those, paint for wheels then paint for bike if her indoors will let me rob the joint account!!
Post by oldelsieboy on Oct 29, 2015 22:20:26 GMT 1
Busy night, stripped all bearings from wheels and hubs, that was easy..... Make sure you keep the reducing spacer/collar from one of the rear wheel bearings OEB
Post by russpuss on Oct 29, 2015 22:21:27 GMT 1
Busy night, stripped all bearings from wheels and hubs, that was easy..... Make sure you keep the reducing spacer/collar from one of the rear wheel bearings OEB Why?
Post by oldelsieboy on Oct 29, 2015 22:23:02 GMT 1
Make sure you keep the reducing spacer/collar from one of the rear wheel bearings OEB Why? Because, like all of the rear wheel spacers, its NLA OEB
Post by russpuss on Oct 29, 2015 22:24:23 GMT 1
Bet that's the 1 that is knackered, does it fit on the end of the spacing tube? Think that can be straitened but the front one is knackered.
Post by russpuss on Oct 29, 2015 22:26:41 GMT 1
Front 3 and rear 5 got mashed.
Post by oldelsieboy on Oct 29, 2015 22:30:12 GMT 1
Bet that's the 1 that is knackered, does it fit on the end of the spacing tube? Think that can be straitened but the front one is knackered. No, AFAIK that one is still available. One of the wheel bearings has a 20mm I/D & there is a top hat style spacer that reduces the I/D to 15mm. OEB EDIT: Item No6 of the fiche.
Post by russpuss on Oct 29, 2015 22:32:33 GMT 1
Bet that's the 1 that is knackered, does it fit on the end of the spacing tube? Think that can be straitened but the front one is knackered. No, AFAIK that one is still available. One of the wheel bearings has a 20mm I/D & there is a top hat style spacer that reduces the I/D to 15mm. OEB Got that 1 then I think, only those 2 got mashed. Phew.
Post by rsvr1000 on Oct 29, 2015 23:00:04 GMT 1
Use genuine throttle cable, check ebay should get one for around £38,
