Post by russpuss on Oct 20, 2015 20:33:19 GMT 1
What's the best tool to use as tried a screw in one and it just stripped the threads, is there 1 that goes over the rim to pull it available? What do you guys use please?
Post by fatfastroger on Oct 20, 2015 20:51:44 GMT 1
I use the threaded one, its a very fine thread and you need to wind the inner bolt right out to get as much of the puller "inside" the flywheel. If the threads are shot you may have to find a 3 legged puller and grind the fingers down to get behind the wheel. You have to be very careful as its very easy to damage the coils.
Post by russpuss on Oct 20, 2015 21:26:35 GMT 1
Got the threaded 1 in as far as it would go but it just pulled right out after force, the windings brown to red was 109 and the Haynes manual says 270 so need to get the stator out. Will shop tomorrow for a 3 legged puller and see what happens with that, cheers.
Post by Yogi on Oct 20, 2015 21:35:23 GMT 1
Just make sure you haven't made the common mistake of leaving the washer in and trying to remove it because it doesn't work
Post by russpuss on Oct 20, 2015 21:43:41 GMT 1
Deffo washer out mate. But it wouldn't go in as far as I would like, there seems to be plenty of threads left to try and get in but it just stops tightening.
Post by fatfastroger on Oct 20, 2015 21:53:24 GMT 1
They can be a nightmare to get off ! Good luck. Mine was a b*****d to remove too. You might already know this but . . . You should "lap" the taper before refitting it too, do this with out the stator fitted as the flywheel will come off the shaft easier during this process, with some fine grinding paste (clean all traces after from crank and flywheel).
Post by Yogi on Oct 20, 2015 22:10:48 GMT 1
Might sound silly but have you got another washer still left in there, I've had that before where some one used two
Post by russpuss on Oct 20, 2015 22:21:19 GMT 1
It was definitely free of any washers, going on everything else it doesn't look like it's ever been off, will try a 3 legged puller tomorrow, cheers.
Post by nick4lo on Oct 20, 2015 23:00:50 GMT 1
mine was stuck solid,used a 3 leg puller and plenty wd40,left overnight under tension,popped off the following morning,let the wd40 work its magic.
Post by bare on Oct 21, 2015 3:32:31 GMT 1
Yikes! 3 legged puller often (usually?) buggers the Rotor. Maybe you were lucky.. maybe you weren't. Once the Rotors threads are ruined/stripped, it's pretty well ready for the dustbin.
Post by Tone on Oct 21, 2015 6:33:31 GMT 1
Might sound silly but have you got another washer still left in there, I've had that before where some one used two And that the outer part of the puller that screws into the flywheel is a LH thread.
Post by russpuss on Oct 21, 2015 7:51:30 GMT 1
Hmm the puller I have looks like right hand thread and it's that that's stripped, so maybe I've the wrong puller?
Post by rich on Oct 21, 2015 8:30:36 GMT 1
I had one that would only go in a few threads as the flywheel threads were a bit buggered. What I did was get a fine hacksaw blade and cut some slots across the threads of the puller in several places so it acted like a large tap. Then I wound it in and out a few times getting deeper each time until it cleaned up the threads and bottomed out.
ps I thought all the M27x1 were l/h thread.
Post by yamark on Oct 21, 2015 12:17:07 GMT 1
All the lads are right here, every comment is valid. Sometimes, they can be a cow to remove.
To get your flywheel off - first have a good quality threaded puller (it should be LH thread). There are loads of crap ones, some I've seen are made of alloy. Spray the crank taper with penetrating fluid.
Take your time to get the puller threaded as far as you can. All washers removed. Tighten the centre bolt tight. Tap the centre bolt with a hammer. Tighten and repeat. Get ready for a bang when it lets go! A little heat can help as well.
A three legged puller risks damage to the stator, flywheel and magnets- only use if you have to. I've known 3 legged pullers to crack the flywheel.
If the internal thread is damaged, I would replace the flywheel
Good luck, HTH
Mark
Let us know how you get on
Post by russpuss on Oct 21, 2015 15:19:14 GMT 1
Good luck, HTH
Mark
Been to Norbo's this morning for a left hand thread, the 1 my mate Bri (come on pal own up) brought was right hand! Tonight is the night, watch this space.
Post by russpuss on Oct 21, 2015 17:39:18 GMT 1
Beauty!
Post by fatfastroger on Oct 21, 2015 19:26:29 GMT 1
Ta da ! Guess it's ok to go back on still ?
gsexr
Post by gsexr on Oct 21, 2015 20:10:02 GMT 1
I do like a happy ending....... steady now yer dirty minded perverts
Post by brian1111 on Oct 21, 2015 20:42:10 GMT 1
Yes and I've been up and put my f--k up right and she's now running sweat isn't she Ross? ?
Post by brian1111 on Oct 21, 2015 20:43:12 GMT 1
Post by 4l04ever on Oct 22, 2015 21:12:32 GMT 1
Glad you got it sorted in the end. My top tip for a stuck flywheel is to pour on a kettle of hot water to help get it moving. Has worked twice in the past for me. :-)
