250 LC
Oct 5, 2015 16:09:50 GMT 1
Post by fifty50 on Oct 5, 2015 16:09:50 GMT 1
Here is my 250LC, it's not a restoration more like ongoing improvements, I've had it since the middle of March 2015, it's a German import had it registered and on the road since June 2015, I've used it since then and have really enjoyed it! Here's a pic of when I first got it.
250 LC
Oct 5, 2015 16:14:26 GMT 1
Post by fifty50 on Oct 5, 2015 16:14:26 GMT 1
I was undecided about which colour to paint it, then in july I came across a tank and plastic set in marsbar colours fitted to bike
250 LC
Oct 5, 2015 16:31:16 GMT 1
Post by stevebgt1 on Oct 5, 2015 16:31:16 GMT 1
You beat me to it ! Was gonna ask what your plans were with it ??
Post by shaunthe2nd on Oct 5, 2015 19:12:53 GMT 1
Get those daffodil wheels sorted and just about there!
Post by fifty50 on Oct 5, 2015 19:47:55 GMT 1
Decided to upgrade to a 350 in july, here is my new to me 350 barrels and head, had them rebored and new pistons ready to paint
after painting with plastikote and baking in the oven.
250 LC
Oct 5, 2015 20:09:56 GMT 1
via mobile
Post by stevebgt1 on Oct 5, 2015 20:09:56 GMT 1
Where did find the mars bar set ? They look great quality finishing ?
250 LC
Oct 5, 2015 20:16:30 GMT 1
Post by risolc on Oct 5, 2015 20:16:30 GMT 1
Tank & plastics look like a right result- as for the wheels I agree with shaun2 -- at least dayglo orange--I have a ratty old pair up the shed if you need them
250 LC
Oct 5, 2015 20:29:01 GMT 1
Post by fifty50 on Oct 5, 2015 20:29:01 GMT 1
Get those daffodil wheels sorted and just about there! I have done, will put some pics up soon!
250 LC
Oct 5, 2015 20:41:27 GMT 1
Post by shaunthe2nd on Oct 5, 2015 20:41:27 GMT 1
Well done, indicators next then! Lol
250 LC
Oct 5, 2015 20:41:21 GMT 1
Post by fifty50 on Oct 5, 2015 20:41:21 GMT 1
Where did find the mars bar set ? They look great quality finishing ? The fella I bought the bike off in March had them, luckily they where still there in July, the finish is very good. cheers
250 LC
Oct 5, 2015 21:22:00 GMT 1
via mobile
Post by Delbert on Oct 5, 2015 21:22:00 GMT 1
Looks good , quick transformation !! Have you sorted a 350 oil pump for your conversion ?
Post by fifty50 on Oct 5, 2015 21:36:04 GMT 1
Looks good , quick transformation !! Have you sorted a 350 oil pump for your conversion ? I bought a recon pump of Arrow in June for the 250, have left the 250 pump on and am compensation with some premix aswell, I have got a 350 pump with shaft that I will probably send to arrow over the winter
Post by fifty50 on Oct 7, 2015 20:39:32 GMT 1
250 LC
Jan 16, 2016 22:11:47 GMT 1
Post by 742xx on Jan 16, 2016 22:11:47 GMT 1
What a difference a change of bodywork made !
Post by JonW on Jan 17, 2016 12:20:38 GMT 1
Looks good , quick transformation !! Have you sorted a 350 oil pump for your conversion ? I bought a recon pump of Arrow in June for the 250, have left the 250 pump on and am compensation with some premix aswell, I have got a 350 pump with shaft that I will probably send to arrow over the winter Adding premix to the fuel weakens the mixture, making it run lean. you will need to retune the carbs for this, as well as upping the jets for the 350 cyls, and you really should fit carbs that are not 4L1 really... the 350 pump and the right carbs (4L0, 31k, PWK28s etc etc) is what you should be doing, it will save your top end investment...
250 LC
Jan 17, 2016 16:32:33 GMT 1
Post by fifty50 on Jan 17, 2016 16:32:33 GMT 1
Have fitted 31k carbs ( std set up 240 mains etc ) and I'm running a small amount of premix to compensate for the 250 oil pump, when I first fitted the 350 top end I sent Arrow ( the oil pump guru ) a message asking about how much premix to compensate for 250 pump, he replied with the amount to use and have done about 450 miles since then all seems well, have checked plug colour and that seems ok.
250 LC
Jan 17, 2016 22:46:49 GMT 1
Post by JonW on Jan 17, 2016 22:46:49 GMT 1
Glad to hear its running ok, did worry for you when i read that as it was a while back. I would still fit the right pump when you can, just my 2c etc. So many people dont realise that running premix weakens the mixture yet theyre convinced theyre doing their engine good by having oil in there.
250 LC
Jan 18, 2016 1:17:15 GMT 1
Post by fifty50 on Jan 18, 2016 1:17:15 GMT 1
Glad to hear its running ok, did worry for you when i read that as it was a while back. I would still fit the right pump when you can, just my 2c etc. So many people dont realise that running premix weakens the mixture yet theyre convinced theyre doing their engine good by having oil in there. Thanks for the advice, that is why this is such a great forum with all the advice and help and knowledge, it's helped me a lot with this bike and yes you,ve got me thinking about sorting the 350 pump out. cheers
250 LC
Jan 30, 2016 17:08:35 GMT 1
Post by fifty50 on Jan 30, 2016 17:08:35 GMT 1
Wheels fitted to bike.
Post by fifty50 on Jan 30, 2016 17:16:24 GMT 1
new tyres fitted. original type indicators fitted.
250 LC
Jan 30, 2016 19:44:08 GMT 1
Post by copper99 on Jan 30, 2016 19:44:08 GMT 1
Much better, getting there mate...
250 LC
Jan 31, 2016 17:17:37 GMT 1
Post by fifty50 on Jan 31, 2016 17:17:37 GMT 1
Seat reshaped and new cover, s/h chrome grabrail fitted and s/h rad cover
250 LC
Jan 31, 2016 17:18:20 GMT 1
Post by fifty50 on Jan 31, 2016 17:18:20 GMT 1
250 LC
Jan 31, 2016 17:23:16 GMT 1
Post by fifty50 on Jan 31, 2016 17:23:16 GMT 1
New gibson pipes fitted.
