Post by sandpiper on Aug 31, 2015 18:59:07 GMT 1
hi guys trying to identify the model, ie uk, restricted, unrestricted, i believe it to mk11 12a, also should this model have round barrell, plus anyone know if this looks like the right carb as cant get her to run properly any help would be greatly recieved as been tinkering with it for 2 weeks now and cant seem to get carb set up properly. P1010401 by jago stretton, on Flickr P1010400 by jago stretton, on Flickr P1010394 by jago stretton, on Flickr P1010399 by jago stretton, on Flickr P1010393 by jago stretton, on Flickr P1010398 by jago stretton, on Flickr P1010396 by jago stretton, on Flickr P1010395 by jago stretton, on Flickr
Post by wonkywheel on Aug 31, 2015 19:51:14 GMT 1
I'm no guru on the LC125, the round head is for a Mk3 which had a longer conrod. The 12A engine was a MK1 So, if you have a shorter conrod with a MK3 head and cylinder it wont run properly. Just a thought. I cant help with the carb. Lets hope the guru chaps can help.
Post by raven13 on Aug 31, 2015 19:56:44 GMT 1
mk3 top end, mk1 bottom end, dt125r carb, providing its got the correct conrod in it, it should run ok
Post by jorjasfather on Aug 31, 2015 20:29:54 GMT 1
Didn't that belong to 2 stroke sole a forum member who built it for hie other half and he had a matching 350lc
Post by sandpiper on Sept 1, 2015 8:49:55 GMT 1
hi guys thanks for the info much appreciated and yes it did belong to another forum member
Post by raven13 on Sept 1, 2015 16:29:12 GMT 1
where abouts are you sandpiper. Might be some local friendly forum member that can help you
Post by sandpiper on Sept 1, 2015 17:59:47 GMT 1
hi penzance cornwall, ive now removed the cyl head to see if the piston goes to top of barrel as told the mk1 conrod is shorter but the guy who built it must of changed it i will upload some pics soon so some members can look at to see if its correct
Post by museumman on Sept 1, 2015 20:36:32 GMT 1
the carb is off an 1985/86 DT125LC YPVS, if the barrel is off a DT then it should be ok but presumably would be using the Dt ignition system, but will go like a DT with more low down power and acceleration. If the barrel is off an RD (usually molded 1GU) then you'll need to set the carb up to suit or buy a '1GU' carb to match. The cylinder heads are the same and both molded '34X'
12A bottom end is off a MK1 and as mentioned should have had a longer con-rod installed for round barrel.
what's the frame number? seems like a right mash-up. DT conversions are fun if done properly, but needs YPVS kit to make it worthwhile. I've got all the parts you need and complete running RD motors if you suspect its a money pit.
Post by sandpiper on Sept 2, 2015 9:48:31 GMT 1
hi thank you for the info will check barrel to see which one is installed, i have removed the cylinder head and the piston travels to top of the barrel so assume the conrod has been changed, would a 10w carb be ok ?? how much would a complete running engine cost
Post by sandpiper on Sept 2, 2015 12:53:21 GMT 1
hi checked the barrel it says 34x, head says 34x, piston reaches top of barrel, 34x-10 carb,should this now run if i can get carb set up, would it be same carb settings as dt125lc mk3 ? at my witts end with it, was told it was all sorted but not the case, p*ssed *ff
Post by museumman on Sept 2, 2015 15:52:50 GMT 1
You need to establish what ignition it's running , although admittedly I don't know what a dt motor would run like with RD ignition timing. DT stators and CDis are quite rare.
If it still uses RD CDI I would fit an RD barrel and carb
Post by sandpiper on Sept 2, 2015 20:22:43 GMT 1
hi thank you for taking the time and advice, the bike runs but after it hits the powerband it seems to run out of fuel have you got a mk3 barrel so i dont have to swop con rod plus is a 12a carb good for this
