Post by muttsnuts on Aug 23, 2015 20:04:27 GMT 1
Ok Guys, just finishing off a build and come to do the brakes and need to work out what front master cylinder to use with the vj22 front end with 6 pot Hiyabusa calipers on, all of you who have done hyrbids will clearly know this, so rather than me mucking about trying to work it out, I thought it easier and quicker to ask the question
Quite happy to buy what people recommend, ideally want one that will accept trick levers etc, can have a seperate or built in reservior
thanks in advance
Post by midlifecrisisrd on Aug 23, 2015 20:46:51 GMT 1
To tokico 6 pots on mine with Fazer master cylinder.
Built in res, and mirror mount. Cheap billet levers widely available and the matching clutch lever fits an lc2 clutch perch with a couple of small spacers. (Paid under £20 for mine. Bought 3 pairs)
No excessive lever travel and have to warn people when they ride it. Brutal braking.
Post by bazzer5115 on Aug 23, 2015 21:58:34 GMT 1
Tokico 6 pots on mine,using standard vj22 master cylinder. Seems fine to me
Post by JonW on Aug 24, 2015 0:22:39 GMT 1
standard RGV is 5/8 IIRC, and I found larger units to be a bit dead feeling so I now have a 14mm version of the same RGV shape Nissin unit from a GSXR I think.
Mine feels like excessive lever travel when being pushed round the garage, but on the road you just need to stroke it with a finger and its good, grab a handful and its brutal. It did take a lot of bleeding to get it to work that well tho, those calipers are a nightmare for that.
Post by Eyrey1 on Aug 24, 2015 1:00:50 GMT 1
use a hyabusa unit dave or gsxr1000
Post by JonW on Aug 24, 2015 1:17:41 GMT 1
I had the GSXR1000 radial unit on my setup, I didnt like it, perhaps the more conventional unit is better?
Post by bofski25 on Aug 24, 2015 7:44:47 GMT 1
hi dave any unit that as got a 14mm bore should work fine most modern bikes use them
bofski
Post by muttsnuts on Aug 24, 2015 9:43:01 GMT 1
ok cheers guys, I'll have a look about and see what I can find on fleabay
