Post by holty on Aug 10, 2015 22:33:09 GMT 1
hi folks, has anyone done a shift star modification, or fitted one of the shift pro kits, or know where i can get one from in the uk please, many thanks.
Post by jessy03 on Aug 10, 2015 22:36:33 GMT 1
Fitted a shift pro, makes the gear change lighter, you can get one from mad biker designs Jess
Post by wallcraft on Aug 10, 2015 22:44:51 GMT 1
I fitted one to from MB designs, simple product that works. Mark.
Post by holty on Aug 10, 2015 23:15:37 GMT 1
can you tell me where they are please, ive googled them but nothing, cheers
Post by JonW on Aug 11, 2015 1:20:41 GMT 1
Plenty on ebay and from the ATV sellers as this is a banshee mod part, Ive got them in my bikes, great bit of kit. You can also round off your old parts to get a similar result, a few guys have done that on the forums if you have a search.
Post by jessy03 on Aug 11, 2015 6:38:06 GMT 1
Post by holty on Aug 11, 2015 8:13:08 GMT 1
Many thanks everyone, great information again.
Post by ianr4863 on Aug 11, 2015 16:59:13 GMT 1
Great product , got one in my 4LO . Martin is very easy to deal with too .
Post by bare on Aug 15, 2015 4:30:11 GMT 1
Geeez Just diy it... it's a 15/20 min job. Fit your OEM star to a board with a bolt as the things axle. Then present it to a grinding wheel. Rotate the star .. grinding the points off all the teeth (except the notched Neutral one) to the same diameter, removing the sharp points. End result should be a series of roundhills, not points for a reference image google or look up the star shape used on Newer Yamahas Fettle to finish the edges. Job Done. Some fit a 'better' bearing roller wheel. Waste 'O time in My experiences.
