Post by tippo on Aug 10, 2015 19:16:31 GMT 1
I have a set of early 350 LC barrels and am thinking of fitting them to a 250 bottom end. I have later 350 carbs (marked 01) that I will also use.
What is the difference in the barrels in terms of performance and why did they change them?
Will the later carbs work OK.
I know I will need a 350 oil pump and engine sprocket etc.. but everything else should be the same??
Cheers
Ian
Post by spondonchris on Aug 10, 2015 20:30:31 GMT 1
You can mix n match the carbs, im running YPVS carbs on later Barrels, i would reccomend 31k ypvs carbs or later 4l01 carbs, as for the cylinders they are modified later on but the early ones will be fine, performance wise i doubt you would tell its all in the set up.
Post by spondonchris on Aug 10, 2015 20:31:11 GMT 1
Read the bible......http://www.rd350lc.net
