Post by stusco on Aug 8, 2015 20:46:03 GMT 1
Is there an easy way to test if my temp gauge is working.Which direction does the drill go to test my speedo?
Post by shunter on Aug 8, 2015 20:55:34 GMT 1
I had the same problem,turn on the ignition and earth out the wire from the sender and the gauge should go up. If it does like mine did the sender is your problem, norbo has these in stock.
