Post by muttsnuts on Aug 5, 2015 12:39:05 GMT 1
Guys, what other options are available that will fit a YPVS rear master cylinder bolt spacing?, the reason I ask is because I've got an LC (4L0) in that has the RGV running gear on, but no rear brake, I've got a YPVS master cylinder and an NK bracket to fit the LC frame, the snag is that the banjo bolt will catch the swinging arm so wonder what others use to ovcercome this issue - I was thinking of somethong like the one fitted to a ducati etc, but don;t want to start buying master cylinders until I find one that works !
I know I could space the foot pegs and bracket etc out, but I'd prefer not to do that unless there is no alternative
thanks in advance
Post by JonW on Aug 5, 2015 13:07:58 GMT 1
There is a Brembo that fits the YPVS spacing, but Ive never used one... I used the RGV one on my LC421 and the YPVS one on my YPVS - both with RGV rear suspension. I did use a brembo on my XT500 SM and I found that it was too tall, so after some research i found they did one with a side exit instead of the top, fixed the issues fast. Worth having a look round, but its a bit trial n error unless youre sure it fits of course and I know you dont want that. :/
(pics of all my 'master' fun on my site of course)
Post by midlifecrisisrd on Aug 5, 2015 13:25:32 GMT 1
The ypvs cylinder always hits the rgv arm so needs the master spaced out a bit and a shallow banjo bolt fitted.
Haven't seen a cylinder with same mounts that doesn't have the banjo on the inside
Post by muttsnuts on Aug 5, 2015 13:55:17 GMT 1
Hi guys, ok thanks, the thing is if I space the master cylinder out then the plunger rod won't fit the brake pedal, I am wondering if the brake pedal has been modded incorrectly and that's part of the issue, thinking it might be back to the drawing board and start a fresh with this rather than trying to make somebody elses various parts fit the bike, which is what the chap has brought to me
I'll have a look about and see what I can find, a side or top exit banjo is what I am after for sure, rear exit is just too close unless I space out a long way and then I am not sure the brake pedal would align easily anyway without more mucking about
Post by alext on Aug 5, 2015 16:51:05 GMT 1
FZR400 - so "probably" FZR600 and some FZ750.....
mine is an FZR400 one.
