Post by iwantalc on Jul 12, 2015 10:12:33 GMT 1
does anyone know what mods are needed to fit these discs to a 350 lc thanks..
Post by LC_BOTT on Jul 12, 2015 11:45:01 GMT 1
Mine just had an alloy disc spacer, to off set the disc. I think the TZR discs are totally flat from memory?
matt7
Post by matt7 on Jul 12, 2015 12:17:16 GMT 1
does anyone know what mods are needed to fit these discs to a 350 lc thanks.. I've got the discs & spacers, not got an LC anymore though, owe me a £bullseye ... You'll then need calipers & brackets. Cheers Matt
Post by iwantalc on Jul 12, 2015 14:32:02 GMT 1
ive already got the discs was wondering what was needed to fit ..if its replacing calipers and other bits i might just try to buy some wavy discs and sell these ones ..thanks for the offer and advise ..
Post by archloafer on Jul 12, 2015 14:56:42 GMT 1
does anyone know what mods are needed to fit these discs to a 350 lc thanks.. You need a spacer for the discs, width would depend on what calipers you are intending to fit. For example, an R6 caliper would hit the wheel if the disc was bolted direct with no spacer, so you'd need a fairly thick one (will be able to tell you precisely how thick in a couple of weeks, after I've got one made for my bike). With other calipers that aren't so bulky you could get away with a narrower spacer, that still gives you enough clearance. Then you you would need brackets for the calipers too. Might be worth giving Nigel at NK Racing a call - think he has both spacers and brackets for common disc / caliper combinations in stock. www.nkracing.co.uk/n3.htmlThose 320mm discs look really good on an LC Cheers - David
Post by iwantalc on Jul 12, 2015 16:03:29 GMT 1
just measured my discs they are 300mm i think the bike has fzr calipers on it.. must be fzr discs not tzr
Post by Norbo on Jul 13, 2015 11:04:34 GMT 1
you just need to space them out and thet fit spot on and then you need to make some hangers for the callipers of course .
Post by iwantalc on Jul 14, 2015 19:04:10 GMT 1
thanks everyone for advise
