Post by bofski25 on Jun 21, 2015 9:07:35 GMT 1
hi all can anybody tell me what the best oil is to run in my gearbox ive done a bit of asking about and some say use light gear oil and some say to just use 10/40w car engine oil all sensible comments will be gratefull
thanks bofski25
Post by 4L0luvvr on Jun 21, 2015 9:37:55 GMT 1
I use Silkolene light gear oil, as I am sure others will on here. The problem with car oil is that it has friction modifiers and other additives in it. Great for your car engine, not so good for your wet clutch!
Post by sp885 on Jun 21, 2015 10:08:54 GMT 1
I just changed mine last weekend, I used Motul Transoil 10-30
Post by rich on Jun 21, 2015 12:42:07 GMT 1
Post by pistanbroke on Jun 21, 2015 13:20:36 GMT 1
That's exactly whit I do, Silkolene 10/40 semi synth in the bike and the rest in the elsie gearbox :~)
Post by 4l04ever on Jun 22, 2015 15:09:25 GMT 1
I use ATF fluid in mine. Supposed to help clutch....
Post by wallcraft on Jun 22, 2015 18:16:58 GMT 1
I to used ATF which was good , nice and light , then I moved on to Coma mineral Gl-4 transmission oil which again is nice and light but also very slick on changing gear. £6 quid a litre from Wilkinsons. Seriously!
Post by stusco on Jun 22, 2015 18:41:29 GMT 1
Coma gl4 from halfords canny mind how much it cost
Post by 2R9 on Jun 22, 2015 20:32:44 GMT 1
Post by tuono1000r on Jun 23, 2015 20:56:47 GMT 1
I was alsoconfused about what to use Haynes manual says 10W30 in one section and 10/W40 in another i went with 10W40 as i also had 1 1/2 litres left over from my blade service. See how it goes eh!
Post by bryan on Jun 24, 2015 14:59:18 GMT 1
As it's now made, get a light 75w gear oil for gearboxes with wet clutch. In the 80s I used Castrol GTX in LCs I had then, but as there is a product available to do the job, why not use it. Don't use a normal care engine oil if you bong get a gear oil, like posts above use bike oil!
Post by Wanderer on Jun 24, 2015 19:22:27 GMT 1
As recommended on this forum i use 75/80 gear oil and i thinks as good as you can get for an eightys gearbox
Post by Fingermaus on Jun 25, 2015 17:37:06 GMT 1
Over the last five years or so I've only used Halfords own brand 10w/40 motorcycle gear oil on my Two strokes. Never any clutch slip, dodgy neutrals, or exploding gearboxes. It states on the bottle that it's as good as leading brands.
Post by farmboy on Jun 26, 2015 17:06:22 GMT 1
Going back to my farming and tractor repair days and all the information gathered over the years I use a Massey Ferguson 10w-30 transmission oil . It meets lots of specs and is made for heavy duty gearboxes , roller bearings and multiplate wet clutches found in powershift transmissions.
I have had no issues with clutch slip/drag or poor gearchange .
I have a 20 litre drum, so even if I change it every 1000 miles it should keep me a while , oh and it was free , used to get loads of oil , still got drums of gear oil .
ATF is good for the clutch but doesn't have the 'hang on' as a gear oil to help gearchange.
Post by wallcraft on Jun 28, 2015 10:44:42 GMT 1
I to used ATF which was good , nice and light , then I moved on to Coma mineral Gl-4 transmission oil which again is nice and light but also very slick on changing gear. £6 quid a litre from Willko's Seriously! Correction £3.50 per litre!
Post by iwantalc on Jun 28, 2015 11:07:14 GMT 1
is this oil suitable for a ypvs engine thanks
Post by wallcraft on Jun 28, 2015 12:27:48 GMT 1
Yep absolutely spot on.
Post by rich on Jun 28, 2015 13:58:51 GMT 1
is this oil suitable for a ypvs engine thanks Yep, YPVS and LC boxes are pretty much identical so same oil requirements apply.
Post by robin on Jul 7, 2015 20:43:17 GMT 1
I just changed mine last weekend, I used Motul Transoil 10-30 +1 just ordered some more for an oil change at the weekend, been using it for years, great stuff, specifically for 2T bikes with wet clutches, not cheap, but she is worth it.
Post by sp885 on Jul 8, 2015 9:29:46 GMT 1
I just changed mine last weekend, I used Motul Transoil 10-30 +1 just ordered some more for an oil change at the weekend, been using it for years, great stuff, specifically for 2T bikes with wet clutches, not cheap, but she is worth it. I'm in Sydney Oz Robin it's about 10 quid a litre here
Post by badger69 on May 4, 2021 11:14:09 GMT 1
I use ATF fluid in mine. Supposed to help clutch.... Petronas Syntium 800 EU 10W-40 Engine Oil 2L 2 Litres (1L X 2) A3/B4 10W-40 Oil is this ok to use in my gear box, many people say use this type of oil is fine, thanks for all replys
Post by chrisg on May 4, 2021 19:21:53 GMT 1
Motul transoil 10/30 for me, but check oil is MA2 specifically for wet clutches on the rd.
Post by 4l04ever on May 5, 2021 12:26:07 GMT 1
I use Comma eurolite now.
Post by elsiefan on May 7, 2021 1:15:36 GMT 1
I just changed mine last weekend, I used Motul Transoil 10-30 +1 just ordered some more for an oil change at the weekend, been using it for years, great stuff, specifically for 2T bikes with wet clutches, not cheap, but she is worth it. +1 I used Motul trans oil when I changed my leaky clutch cover gasket, seems to work nicely and got it with a bulk discount including some 710 and Motul coolant.
