Post by iwantalc on Jun 18, 2015 18:37:15 GMT 1
looks like ive got a slight oil leak from gear shaft is this a easy fix and does the engine have to come out to do.its a ypvs engine in lc frame thanks
Post by kostas on Jun 18, 2015 20:55:27 GMT 1
No, pull the seal out with a pick and press in the new one.
Unless... Gearshaft has a wear groove on it or if the bush behind the seal is worn out.
Gearshaft means that you have to pull the r/h case. Bush means that you have to live with the leak until the time comes to split the engine.
Kostas
Post by iwantalc on Jun 18, 2015 21:06:06 GMT 1
thanks for the info will look into this further ta kostas..des
oil leak
Jun 18, 2015 21:40:44 GMT 1
via mobile
Post by midlifecrisisrd on Jun 18, 2015 21:40:44 GMT 1
Not tried it but technically the bush should be removable with an internal bearing puller.
Also it has been said that the gear shaft passes through a chamber that the bush cannot get out of so theoretically you could drive another bush in and it would just sit in the cavity or if you made a driving tool it would just sit on the shaft. Would be a fix till a strip was on the cards.
