Post by iwantalc on Jun 14, 2015 17:31:39 GMT 1
just dropped pipes off at parcel shop sending to jeff at blastcoat going to have them ceramic coated but with a gloss finish not matt. jeff said they will be the 1st ones he has done in a gloss finish i think they will blend in with the bike better oh well only time will tell fingers crossed will look ok
Post by oldelsieboy on Jun 14, 2015 17:39:28 GMT 1
just dropped pipes off at parcel shop sending to jeff at blastcoat going to have them ceramic coated but with a gloss finish not matt. jeff said they will be the 1st ones he has done in a gloss finish i think they will blend in with the bike better oh well only time will tell fingers crossed will look ok I hope they make a better job of ceramic coating than they did powder coating a set of LC wheels OEB
Post by iwantalc on Jun 14, 2015 17:54:59 GMT 1
just dropped pipes off at parcel shop sending to jeff at blastcoat going to have them ceramic coated but with a gloss finish not matt. jeff said they will be the 1st ones he has done in a gloss finish i think they will blend in with the bike better oh well only time will tell fingers crossed will look ok I hope they make a better job of ceramic coating than they did powder coating a set of LC wheels OEB i hope so someone did have a set of tsa;s on here and had them ceramic coated by them and did look nice.were the wheels that bad ?.might have to quote them on this..did you complain?
Post by Delbert on Jun 14, 2015 20:03:05 GMT 1
Every one gets a lemon now and again
Post by alistair64 on Jun 14, 2015 20:54:40 GMT 1
Every one gets a lemon now and again True, but if the company is worth using it should look at everything it turns out and either accept or reject it...not just hand it back to the customer if it hasn't turned out right. Well, at least that's how I operate at work.
Post by oldelsieboy on Jun 14, 2015 21:07:26 GMT 1
Every one gets a lemon now and again True, but if the company is worth using it should look at everything it turns out and either accept or reject it...not just hand it back to the customer if it hasn't turned out right. Precisely, I will not be recommending their services. OEB
Post by Delbert on Jun 14, 2015 21:20:06 GMT 1
Every one gets a lemon now and again True, but if the company is worth using it should look at everything it turns out and either accept or reject it...not just hand it back to the customer if it hasn't turned out right. Well, at least that's how I operate at work. absolutely agree with you , that's how I operate too , perhaps I shouldn't have been so blunt ,, I assumed rightly or wrongly oeb had a bad job done but all was sorted ,,, my bad
Post by oldelsieboy on Jun 14, 2015 21:43:28 GMT 1
True, but if the company is worth using it should look at everything it turns out and either accept or reject it...not just hand it back to the customer if it hasn't turned out right. Well, at least that's how I operate at work. absolutely agree with you , that's how I operate too , perhaps I shouldn't have been so blunt ,, I assumed rightly or wrongly oeb had a bad job done but all was sorted ,,, my bad Whether it is sorted or not a job should not be returned to a customer until it is completed to a satisfactory level, not returned just because you are "too busy" to complete correctly. OEB
rd84
Post by rd84 on Jun 15, 2015 23:45:50 GMT 1
Post by bare on Jun 16, 2015 4:12:49 GMT 1
Wasn't too long ago that Ceramic Heat Barrier coatings were Banned! For Aviation usages Reason being that Ceramic heat barrier coatings reduced the Metal fatigue resistance by 50%. Not good to have bits falling from the sky. Likely not a big issue on a seldom ridden bike/scooter though.
Paul H
Post by Paul H on Jun 16, 2015 14:40:19 GMT 1
I hope they make a better job of ceramic coating than they did powder coating a set of LC wheels OEB i hope so someone did have a set of tsa;s on here and had them ceramic coated by them and did look nice.were the wheels that bad ?.might have to quote them on this..did you complain? i Think it was Mick Geary that had his TSA's done
Post by raven13 on Jun 16, 2015 20:14:39 GMT 1
yes mick did have his tsa's done by them and a really nice job they made of them. I know 4 or 5 people that have used them and not one has a bad thing to say.
Post by iwantalc on Jun 16, 2015 20:18:44 GMT 1
well hopefully all will go ok should look different with a gloss finish and polished alloy end cans.
Post by ringdingding on Jun 16, 2015 22:44:23 GMT 1
I had a set of TSAs done at Camcoat in Warrington, quite a long wait, but stunning finish and rather expensive. But I'd certainly recommend them
rd84
Post by rd84 on Jun 17, 2015 15:59:02 GMT 1
I had a set of TSAs done at Camcoat in Warrington, quite a long wait, but stunning finish and rather expensive. But I'd certainly recommend them Many thanks.
Cheers Paul
Post by cinder on Jun 17, 2015 18:35:04 GMT 1
I have used Camcoat and my order went through in 2 weeks to a good standard I used the chrome effect and am happy with their work
rd84
Post by rd84 on Jun 18, 2015 14:28:46 GMT 1
I have used Camcoat and my order went through in 2 weeks to a good standard I used the chrome effect and am happy with their work Thanks for the info - That's good news - I've ordered a set of pipes from Kenny at TSA - so I'll probably use Camcoat given the responses above.
Cheers Paul
